“Fishing” inertial propulsion…
iacob alex
Post by iacob alex »
….with some prototype devices , at :
www.stellarotor.com/2022/03/20/prototype-images
Al_ex
Re: “Fishing” inertial propulsion…
Someone has spent a lot of time and effort on the Stellarotor concept.
iacob alex
…..with a simple proposal ( a possible centrifugal “propeller “ ? ) :
-on paper , at : www.geocities.ws/iacob_alex/Inertial_Ro ... led036.jpg
-an elementary assembly , at : www.geocities.ws/iacob_alex/Disclosed_e ... ab0011.JPG
Al_ex
iacob alex
-on paper , at : www.geocities.ws/iacob_alex/Inertial_Ro ... led036.jpg ( pos.3 )
Al_ex
iacob alex
iacob alex wrote: Sat Oct 07, 2023 1:41 pm …..with a simple proposal ( a possible axial centrifugal “propeller “ ? ) :
Al_ex
[ Progress ]
Hello iacob alex
How are you progressing on this concept?
iacob alex
Hi Agor95 !
Regarding this subject…I made a single blank experiment ( low rpm…) , with an unique crude ( non evolved ) model (2008) , only.
Al_ex
iacob alex wrote: Sun Oct 08, 2023 6:33 pm I made a single blank experiment ( low rpm…) , with an unique crude ( non evolved ) model (2008) , only.
Sensible way forward by starting with a low cost test.
Then use that test too weight the worth of progressing more.
Thank for the reply
iacob alex
Hi Agor95 !
Thank you for suggestions…as you know : usually we need the test first , the lesson/idea after !
If the idea can be the root of creation of “something “ related to physical world , it must be tempered with our games of reality.
I hope for a new test…
Al_ex
iacob alex wrote: Mon Oct 09, 2023 3:21 pm ... related to physical world ...
There is forced discipline in grounding ideas with engineering.
Some find it a painful fall when the stark reality that their knowledge is incomplete.
As their idea is in the air and they drop.
iacob alex
…..with : www.geocities.ws/iacob_alex/Inertial_Ro ... led026.jpg (pos.34)
…..intended to play inertia as a tractive propeller.
Al_ex
iacob alex wrote: Sat Nov 11, 2023 10:53 pm …..with : www.geocities.ws/iacob_alex/Inertial_Ro ... led026.jpg (pos.34)
Al_ex
This is an intriguing original design. Odd I woke this morning thinking on the first of my 4 concepts.
It can use two egg shaped cams. Here is an image that also involves two possible cams.
iacob alex
…..with : www.geocities.ws/iacob_alex/Inertial_Ro ... led025.jpg (pos.38)
We minimize a common concept with three spare parts (piston-connecting rod-crank) into a two spare parts (rotating-sliding rod and crank ) only…..intended to take advantage ,controlling rotational inertia in a half plane.
Al_ex
iacob alex
…..with a controllable double pendulum ! ?
Starting with some introductory sites :
https://en.wikipedia.org/wiki/Double_pendulum
https://i.stack.imgur.com/ibCXc.jpg
https://www.scienceabc.com/pure-science ... dulum.html
…..and thinking/ playing as a “two sticks game…” ( see a topic of this forum ) , we can simplify our interactions with reality.
A double pendulum : two sticks , two full rotating joints ( fixed,mobile ) in a 2D planar “space”…exhibits an irregular , uncontrollable trajectories…..as an “untamed “motion.
The motions of the same double pendulum can be “tamed” if we introduce a third fixed rotating-sliding joint …and playing it “double” , as :
www.geocities.ws/iacob_alex/Inertial_Ro ... led033.jpg (pos.13).
Al_ex
iacob alex wrote: Wed Nov 15, 2023 3:01 pm …..with a controllable double pendulum ! ?
Welcome to my world. Just look at the formula and imagine doing that in 3 dimensions X, Y, & Z.
Also note you have to integrate using a numerical method [iterative program].
The default Euler integration method is know to increase energy by error.
So other Runge-Kutta methods are used to improve accuracy.
https://en.wikipedia.org/wiki/Runge%E2% ... ta_methods
