After more than two years, I quit.
Weights would have to be lifted for it to work, and that isn't going to happen.
I'm declaring Bessler's wheel is impossible to solve.
Re: I'm declaring Bessler's wheel is impossible to solve.
There lot's of different ways to lift weights. But sometimes a break is good.
For your morale, I recommend reading this thread in its entirety... you're not the same person when you leave and who knows...
http://www.besslerwheel.com/forum/viewt ... e11a9000f0
The world is perfect.
Hello ArchCalc
Your current position is understandable.
Looking for a non-intuitive way forward in not easy.
Building on what we know is the main path most follow and reach your declaration.
I stopped lifting weights along time ago due to the impossibility and looked at masses
following their natural paths.
In the process I hit missing areas of knowledge.
That resulted learning and changing as each is acquired.
I gained from the process independent of 'The Quest'.
All the Best
All the Best
Welcome ArchCalc. Feels good to be right.
We aren't necessarily saying Bessler was a fraud, but after 300 years culminating in this enlightened era and no one has solved it? Yep and it won't be either.
Perhaps broaden your search criteria ..
* No passive leverage technique (Law of Levers, and MA x SR = 1.0) can give a lift of higher PE than you started with .. (what you said) ..
** Leverage can be put to use to give a required lift (Net gain in PE) if the wheel has a replenishing source of Input energy to be transformed into Mechanical Energy Output i.e. energy consuming engine analogue .. (not usually accepted as true mechanical PM)
*** Therefore, imo .. B's. wheels, once in dynamic mode, induced a push of momentum to cause the repeatable circulation of weights and gaining in wheel momentum/RKE, et al .. and the OB system, starting from out-of-balance, provided the initial torque to prime the dynamic phase of parasitic momentum exchange from the wider environment surrounding the wheels ..
Road blocks are temporary, until you find a way around them .. mental road blocks are harder to get around ..
A heavy disc rolling around inside of a drum can lift the weights back up. But don't take my word for it; try it and see--Sam
either in this life or the next.Road blocks are temporary, until you find a way around them .. mental road blocks are harder to get around ..
It's only a belief, yet I think 2023 is the year.
