But you wanted to discuss OS and DOS. And now you say I should talk about Bessler? You said MicroSoft allows you into the DOS. ShowWaltzCee wrote: ↑Wed Aug 23, 2023 5:09 amYou should follow your own advice.UbWe wrote: ↑Wed Aug 23, 2023 3:56 amNot in Linux. They use radians. Quit lying.
Is this why you like your Montana farmer? She lets ewe sleep with the livestock?Please learn your OSs,
- Oops, he said sheep shed and föcked a sheep.
it's sad when you attack Linux when you apparently don't use their OS. It shows.
p.s., Please discuss Bessler and his work. I think we are evolving to the point of saying Bessler's work can be realized.James-Alan wrote:And I did not say you attacked Linux.
That is what matters. I'm not Bessler just as you aren't. I think he deserves respect for his work.
me. How do you modify your OS from your DOS? I want to know because you wanted to talk about it. You went there and I am following your lead.
You went off topic so you need to explain yourself. I can change my DOS but you can't and yet you say MS allows you to do so. You need to explain
yourself for changing the topic of this thread. You made it about you can change your Microsoft OS when you can't.
I think once Pentium moved up from the 486 chip that Microsoft quit allowing access to its DOS which became proprietary information they don't like sharing. You started this, don't tell me to follow my own advice when you took over the thread with something you can't do. And yet you attacked Linux saying that values other than radians could be calculated when they can't be calculated because Linux simply doesn't allow for it. I know my OS and
the office suite I use. That's why I get work done. I entered every sine and cosine value from 0º to 90º manually. If I wanted to use a spreadsheet for
what I want then that is what I had to do and I did it. Don't discredit me for doing the work when I knew I didn't want to work in radians.
p.s., When it comes to Bessler, if Jubat is willing to learn how algebra and calculus applies to his work, then he might be a good representative for Bessler and his work. I'm not Bessler and Bessler's interest comes first. And for what I'm doing, that is important.
