CENTRIFUGAL SPIRAL WHEEL.
savoniuspiral
Post by savoniuspiral »
Hi,
The basics of this design, uses a pair of smaller spirals (slave spirals), The force applied by a mass, on the downward/outward ramps utilize centrifugal force, to rotate the main wheel frame with excess power.
the spirals in this version are Archimedean spirals, similar to MT 43, they expel 4 loads outwards as the spiral turns 360 degrees " one every 90 degrees".
( a 1 kg ball on this 1 meter radius constant ramp spiral is the same force as a 1 kg weight on a cord wrapped around 15.915 radius pulley "excluding the cord weight and friction).
A larger spiral with a 2.2 meter radius (the master spiral) is used to resupply the balls or (fluid).
The wheel would be horizontal, so that the system does not need a 2.2 meter spiral to keep the flow continuing in the slave spirals.
The calculations below are based on a vertical wheel.
The pair of the 2 meter diameter slave spirals, are attached to the main rotational wheel frame at a distance of 1 meter from the center axle.
The slave spirals turn in opposite directions, in this version they turn 2 times the speed of the main wheel frame.(gearing can be changed for different rotation ratios).
the slave spirals are connected to each other on the wheel frame by gears, one of these slave spirals central gears, connects to a stationary central sun gear.
the slave spiral gear rotates around the stationary sun gear.
The calculations below are based on the slave spirals turning 720 degrees on the wheel frame when the main whel turns 360 degrees.
each spiral would eject 8 balls per revolution of the wheel.
First calculated a reference speed of 1G on a horizontal wheel in which the mass is at 1 meter from the center axle.
a mass at 1 meter distance from the axle = 1G when the wheel turns 29.91 rpm.
step 2: work out the centrifugal forces on a 1 kg mass when wheel speed doubles.
29.91 rpm = 1G
1 kg = 1kg
29.91 x 2 = 59.82 rpm
1 kg = 4kg
59.82 x 2 = 119.64 rpm
1 kg = 16kg
119.64 x 2 =239.28 rpm
1 kg = 64kg
If the wheel speed is at 59.82 rpm, the 1 kg mass, at 1 meter from the center main wheel axle has a mass of 4 kg. (on a horizontal wheel)
It takes 1.003 seconds to lift each ball at 59.82 rpm.
to lift 1 kg 1 meter in 1.003 seconds = 9.777 watts (slave spiral)
16 * 9.777 = 156.435 watts.
to lift 1 kg 2.2 meters in 1.003 seconds = 21.509 watts. (master spiral)
16 * 20.532 watts = 344.158 watts.
The slave spirals mass is at 4G, It actually increases as it travels down the spiral, it exits at 2 meters from the main wheel center axle.
4* 156.435 watts = 625.742 watts
the balls enter at 1 meter distance form the wheels centeral axle, but exit at 2 meters from the main wheel center axle. so the force when it exits is twice that of the entry point. if 150 cm was the average output the slave spirals output = 938.614 watts.
The slave spirals turn 720 degrees on the main wheel frame, when the main wheel turns 360 degrees.
The wheel now gets 2 * the torque.
The main wheel output =1,877.228 watts.
Power needed to lift the 16 balls = 344.158 watts.
output power of the main wheel = 1,877.228 watts.
output to input ratio = 5.454 to 1.
if the wheel still turns at the same rpm and the spirals are geared to turn 4 times the main wheel speed, this output ratio also doubles.
Ratio would be about 11 to 1.
if the wheel speed doubles, the ratio also increases.
The horizontal system would have a better input output ratio, due to either using a siphon system or a vertical spiral that has a smaller diameter, as it would not need to lift the fluid as high compared to the vertical system.
Is the math's correct ?
If it is, the system has great potential to self rotate with plenty of excess power to turn external systems.
Note: could not animate either balls or water traveling through the spirals.
links to videos of various designs.
https://www.youtube.com/watch?v=v5PpRBWhrHU
https://www.youtube.com/watch?v=udBoqLazt3k
https://www.youtube.com/watch?v=_keQ5Ez2vhk
https://www.youtube.com/watch?v=u75gBjbJbnc
Re: CENTRIFUGAL SPIRAL WHEEL.
Hello savoniuspiral
Excellent work for you have developed a high level presentational style with multi-software transfers; so you reach a larger audience.
The use of illustration and animation is important. The next level is simulation and then on to fabrication.
May I suggest you consider a spiral where the fluid volume reduces as it flows down the spirals length.
The rational is the fluid flow increases and that is catered for by the reduce volume.
Therefore the exist speed is not hampered by back pressure.
This will result a more powerful jet on exit.
savoniuspiral
Thanks for the tip Agor.
used the ordinary arithmetic type ramp because it's easier to perform calculations by exchanging fluid for the 1 kg balls.
"as its similar to a rope around a pulley".
If i decided to build one of the variations, it would be the horizontal siphon system. That system would need to go through a pipe etc ,it would have a continuous flow.
calculating any type of tapering angles or even non constant ramps etc for the best flow or pressure is way above my math skills.
High end simulation software would be needed.
The horizontal siphon design is still a work in progress.It could be a little more efficient if the spray flowing out hit blades on the perimeter of its wheel.
Still have another design that would be a huge improvement over these spiral wheels, as it doesnt use gears.
unsure what to do, still 50/50 on whether i should post it.
Is there a group similar to Arrache, that could help out, if it's viable ?
savoniuspiral wrote: Sat Apr 20, 2024 9:13 am used the ordinary arithmetic type ramp because it's easier to perform calculations by exchanging fluid for the 1 kg balls.
You get respect for trying too further the study of fluid dynamics.
The calculations get out of people's skill level vary quickly.
Here is a link to some software that is out the on the web.
https://www.youtube.com/watch?v=lMNPQCmhkDs
A simple case can become complex.
Take a horizontal spiral with that reduction in volume feature.
Now rotate the spiral around the path of the spiral.
You can simplify by using small frictionless spheres to emulate a fluid.
Having a target for the jet is useful for the fluid ends up colliding with itself.
That adds to the basic inertial jet thrust.
The value is the collisions that happen when the fluid has the most momentum.
Nice work savoniuspiral. Not sure if it will work but I have a design for a double spiral lift witch uses counter torqueing spirals. If I find the time I will post it on my thread. It might help you?
savoniuspiral
Thanks daxwc,
if it leads to improvements, the help is welcome.
Agor,
That software would be advantage when trying to design systems that utilize a flow.
"only after years of learning how to use it".
Unfortunately these CF based designs are above my build capabilities, i avoid building any system that turns at high rpms, can get deadly if it breaks apart.
Can't even afford the gears. currently use chains sprockets and laser cut gears, that only add to the friction.
savoniuspiral wrote: Sun Apr 21, 2024 5:54 am ...
All that follow 'The Quest' deal with the same issues of build capabilities, time and money.
The one thing that is more time dependant is system design and analysis.
After building a bolsawood, sellotape, cotton thread & coin mock-up of MT25.
This first build gave me an understanding of my build capabilities.
That is why I spent 16 years working on the system design and analysis.
Plus a communication web server platform with other auxiliary modelling software skills.
So analysing your design and looking at each element helps understand it's kinetics & dynamics.
I only built my second device after gaining that understanding.
