MrTim's wheel progress
MrTim
Post by MrTim »
This is a Gera-size wheel (it was a real pain to build.. ;-)
50 inches in diameter, 4 inches thick (it will be closer to 5 if/when the outer casing is put on.)
The bearing blocks weigh more than the framework(!) and the wheel spins freely on the axle.
The support base was made to fold up so that it could be put in my car.
Also pictured is my esteemed colleague, Professor Goodstuff... ;-)
Still need to build the mechanisms that go inside... ;-)
Gregory
Re: MrTim's wheel progress
Post by Gregory »
That's looking good, MrTim!
Professor Goodstuff is also a decent addition to the collection! :)
Hope your assistant doesn't run off and tells everyone it was cranked next door .
MrTim
Post by MrTim »
johannesbender wrote: Mon Mar 31, 2025 7:27 pm Hope your assistant doesn't run off and tells everyone it was cranked next door .
LOL, he'd never do that. But he does complain that it's too cramped for him to run along the inside of the rim to turn it... ;-)
Looking good Mr Tim .. Mr Goodstuff is showing how it could be scaled up ;7)
Good luck Mr Tim. Good to see someone actually buildling.
thx4
Post by thx4 »
Beautiful construction, the best for the future.
Good luck Mr. Tim for your internal construction.
I am actually installing the wheel in Bad Karlshafen
first run to test the axle
https://www.youtube.com/shorts/CnrhaUuL ... ture=share
The wheel is the basic for the one and the bi-directional wheel.
The moment of inertia of the bidirectional wheel is not yet correct.
The carpenter is working on the internal part.
Maybe I must use some lead.
