The ANSWER ???? - Hit NOW !!!!!
Posted by Gill Simo (193.195.0.102) on March 13, 2003 at 07:45:25:
Hi everyone
I genuinely believe the following to be IT .If it isnt then the people of 1st Dynasty Egypt were making some crazy bearings or toys! If you are, or know of, someone knowledgeable in forces/power from an axle then please mail this on ASAP.
Ed Ledskelnin of CORAL CASTLE, FLORIDA fame insisted that magnetism and electricity were but 2 components that made up 1 universal energy.
That energy he assured us was a spiral turning c/wise, the magnetism component, and a resultant straight down the middle movement, the electrical component, the resultant vector of a turning spiral, the apparent flow to the left or right along its length. To this Ed insisted even more assuredly that there was a resultant spiral turning in the opposite direction with its vector travelling down the middle in an opposite direction.
Like DNA, a twisting of one spiral flowing in one direction against another in the opposite direction. Ed told us that when we connect an amp meter to a circuit and see a negative deflection to the left we assume that our one-way meter in connected in reverse whereas in truth we are measuring one of the 2 opposite current that always flows. If you want to see both connect 2 meters, one reversed!
Was he right? Is there one universal energy flow like this?
Bearing this question in mind please now consider the following.
PM is about capturing this available universal flow of energy, about creating some situation whereby energy flows both ways along the centre, the axle, of a turning double helix. This axle/turning leads in all obviousness to a wheel but this wheel in itself is obviously impossible for what we need is a wheel that turns in opposite directions about an axle whilst at the same time maintaining a connection along that axle in some ingenious way. So, if we twist a normal axle in this manner it would clearly deform, it would twist into a spiral. Imagine it to be made of rubber and youll see that in twisting your energy INTO this axle then you have to let it go to release that energy and it will be released along the axle in the direction as your twisted rubber axle unwinds. For PM we need the impossible, a true split axle whereby if you spin one axle then the other end responds equally and opposite.
Well in fact it isnt impossible at all, its utterly obvious and in the name of God, why nobody has ever noticed it is beyond belief.
HERE IT IS THEN !!!!!!!!!!!!!!!!!?
On some surface place a see-through tube, so that you can drop things into it. This drums diameter is such that it will accommodate 6 balls sitting at the bottom arranged as per a triangle. Place in these 6 balls. Place 1 ball into the centre of these 6. Arrange a further 6 balls around this, so another triangle this time filled in by a 7th central ball and inverted upon the 1st triangle. Place a 3rd set of 6 balls into the drum. 19 balls in total. Place the drum on its side and into either end `plug` a Saqquara Bowl (you will see that they plug in, to perfection) each with its own axle already placed through it. Place this in supports and THAT IS IT. 666 and 1 in the middle!
As you turn one bowl so the other turns in the opposite direction and this is achieved by the movement in the 19 balls. All are constantly moving in a spiral between the 2 bowls, spiralling around and along the around and along in the opposite direction. Glue 3 balls together, make 3 of these and have a ply with the 9 balls that fit into these 3 triangles, one upon another and youll soon see the truth in this. You can add balls either around and/or along the axle, it just gets more torque flowing out of either end of the axle and remember that the axle is split, if you looked along it from one end then it would be turning in the same direction when viewed from the other end so its not torque as already known, i.e. a cancelling thing, here the torque from one axle is adding to the torque from the other.
Why does it spin? Well I have tried recently to suggest that weight around the axle in the normal sense is a non-star on that PM device
Being NEW then this has to have some new theory, something that if accepted and understood becomes a new principle. Like Bessler I cannot say for certain why this works, I can only theorise and insist that it is true, that nobody has ever thought to throw a few balls together, plug an axle into either end and watch it go!!!!!!!!!!!!!!!!
Talking of Bessler
Rain drops = falling
Snow falls = turning
Gun shoots = spiralling
Bow twangs = Oscillating as in frequency
Acrobats = tumbling
Shadow boxer = equal and opposite
Fat, plump lazy horses = cows/bulls(balls)
Wandering aimlessly around = what these balls do
Axle that in its turn moves = just that
Moves to the left/right, turns in either direction = just that
All the toys on his one page relate to the ball movements,study and you will see
As you study this device and the movements within so you will begin to see the ancient and esoteric symbolism etc in its obviousness also. This energy was known and understood before and I for one believe that America knows of and wishes to announce it upon an unsuspecting world and as it all falls apart then they will have control, control of the oil required in order that the great THEY can rule over the great US and our new toy until their new order is established. Have we beaten them to it or is it too late now anyway ?
You may have difficulty in seeing all of the above but a few marbles, a pen, paper, compass set; ruler etc and a late night should get you there
GOD PROTECT US ALL Gill Simo
