MORE/Opps, almost forgot one...
Posted by David (199.60.107.1) on March 21, 2003 at 17:26:32:
In Reply to: Re: The Wheels Secret, revealed/MORE posted by David on March 21, 2003 at 13:36:40:
Besslers first statement of his clues,
>let him ponder the rich pageant of words
which I now cause to shower down upon him!
SHOWER! Again, water.
I was a bit rushed so I realize my very first posting on hydralics may have been a bit convoluted, so in case I'm not fully understood.
1. A wheel with an inner pressurized chamber (positive or vacuum), extending outwards from this in spoke like protrubances towards the outer rim are hollow tubes, inside of which are pistons.
2. When the paired weights are at the 9 and 3 oclock position a lever is engaged which releases a small amount of pressure, causing these weights to move to the side, where one is closer to the rim, one is further away. Gravity causes the wheel to move, disengaging the lever. A spring is used to pull the lever to close off the pressure.
3. The torque generated by the movement of the wheel is used to run a pump to feed some energy "pressure" back into the "heart" ei. pressurized chamber, of the wheel.
4. Possibly an ideal arrangement of weights and their movement was employed so very little energy was used to move them.
