Re: Also
Posted by John Collins (194.164.38.102) on April 24, 2003 at 12:08:38:
In Reply to: Also posted by David-Moses on April 24, 2003 at 11:28:04:
:I think I mentioned all this before. I discussed the differences in the two kinds of wheel in my book taking several pages and going over it all with a fine toothcomb. I don't want to do it all over again David. It seems obvious to me that, in the case of the one-way wheel, when the wheel was stopped, the weights came to rest in an unbalanced position, and once the wheel began to revolve, gained force from the swinging which then occurred.
In the case to the two-way wheels, I suggested that faced with the accusation that his wheels must be wound up, Bessler thought that if he could show that his wheels could turn in either direction that would seem to prove that they could not be wound up. So he thought of trying a mirror image mechanism in his wheel to see if they would react in exactly the way that they did. This would counteract the spontaneous starting of the wheel and obviously it needed a push to start it, since it could turn in either direction and it could hardly spontaneoausly begin to turn under those circumstances. The amount of push is subjective and also subject to the vagaries of translation. One man's two finger push may well be the same as a tolerable push by someone else.
The evidence which I went over in my book agrees closely with the above scenario. The two-way wheels could only turn at half the speed and they were twice the thickness of the one-way wheels. I even carried out tests with a Savonius windmill, one on its own and then two fixed to the same axis but facing opposite ways. They reacted in exactly the same way. the single one spontaneously began to turn in the wind and the double one needed a shove to start it and then only turned at half speed.
Hope this helps.
John Collins
snip...Except Bessler stated there was very little difference between the wheels, at least of no consequence, and, once the wheel recieved a full rotation the perpetual motion principle took over, the the wheel gained the force of its rotation from coordenated swinging weights. Are you saying the weights were always swinging?...
: Even when the wheel was still? You are also inplying a difference in weight setup between the bi directional wheel and one directional. This implies Bessler found not just one but two methods of perpetual motion by weight, does it not?
