Re: Question to John Collins
Posted by Darren (208.143.232.66) on May 12, 2003 at 11:49:00:
In Reply to: Question to John Collins posted by Seok Kyun Oh on May 12, 2003 at 03:39:48:
: I have studied for 2 years about the wheel, and I get to a conclusion that building the wheel need great accuracy.
: I am building the wheel with the LASER Cutted parts, because accuracy of the LASER cutting is within the error range of +/- 0.3 mm.
Just a note here... Bessler did not have a laser cutting tool... if his wheel was real it did not require that degree of accuracy.
If you have a design that has specs that tight then I would guess you're wheel probably balances and a small mistake somewhere in your calculations is showing you some teency bit of over-unity.
I'm sure that OU will come pouring out of a working Bessler wheel and it would be very easy to calculate extra OU. You wouldn't miss it.
Darren
