message to OVYYUS
Posted by murilo (200.168.8.167) on May 21, 2003 at 11:11:05:
Hi, Bill. The good labor you are doing forces me to congratulate and to thank to you. It helps a lot in the appreciation to that german genius. Personaly I think that if his best solution would use a very special CLUE, it would be very clear in some draw, at least in part. So, I believe that the Bessler wheel should use, as he said, combined solutions that are all there. I confess that some draws I couldn't understand... do you? Is this case, you must be so well trainned, that I would ask you for to take a look to my own conceptions, of sure when you get time. They are hard to be understood, and flexible trainnig and patience must be used, just before the comming of a flash!! A kind of challenge! Can you give me a hand, please? (you'll find them at www.alzimach.net , in Gravity Motors,''FRCM,Fractioning...''). Thanks again. All best! Murilo SP may/21
