Re: to Bessler's croud
Posted by Scott Ellis (206.168.33.195) on May 27, 2003 at 14:35:52:
In Reply to: to Bessler's croud posted by murilo on May 27, 2003 at 12:10:01:
Hi Murilo,
Thanks for your post. I just wanted to add that I have posted your drawings and documents to my Ideas section. Sorry it took me so long! Better late than never...
Happy Hunting!
-Scott
: Hello. Pls try to understand me. Let's make a temptative for to join some stuffs. At a few weeks, Darren wrote a msg teeling me about some ''familiarity'' between my ''avalanchedrive'' and the draws 49 and 50, and I think he's a bit right, besides he wanted to mean that I copy to them, what is his ABSOLUTELY mistake. BUT, let's think a little. In somewhere there are a CAD draw with a Bessler wheel, in wood, where there are also 2 other small wheels in vertical line to axis. If you go to draw 49, you can see this wheel there, in rough construction. IF you assume for this kind of wheels (that present a wheight set in form of a letter ''D''), a body constructed just like to the CHAINS that I use in my conceptions, you'll see that it MAY WORK FINE, IF some complementary connections are solved. If the chain rises in the vertical straight D's segment and falls in a half turn in contracted zigzag it will work. In somewhere people says about the syncronous movement of 2 wheights, and they may be that one in bellow and that in top (up and down), wich leaves and reachs, together at the D vertices. They say about cilinders, and these can be the chain's segments, elements for the zigzag that expand and contract, and THESE zigzag elements, as we can assume, may be joined by SPRINGS, for to help contraction and openning. I'M SURE that any conception based in ''chain sets'' would be EXTREMELY HARD for to be hidden, and covered in semi-shadow. A tip for a chain may be in draw 50, that uses small free balls in each segment and that is a clear flaw. The use of chains is, possiblely, the only solution for a ''gravity turbine'' that will be able to send POWER SURPLUS, and I still preffer the resources and possibilities of my draws wich use an elipse, besides a ''D'', or half wheel. (be patient to my english, pls!) I came to know to Bessler thoughout this group, in last march, only. If I could copy to something I didn't know, Darren could also copy to something he should know... THE HOT CLUE IS THE CHAIN, time will say. ''Avalanchedrive'' borned in my mind in nov/1989. When I have some impulse for to be proud of it, I remember my short reallizing capacity, up to now. I'll thank for comments. Best regards. Murilo SP may/27
