Re: Experiment 34 Perpetual Motion theory
Posted by RW (66.177.116.68) on September 29, 2002 at 12:22:42:
In Reply to: Re: Experiment 34 Perpetual Motion theory posted by Øystein Rustad on September 29, 2002 at 00:57:01:
Hello,
While the battery was powering the Turbulent Airflow Generator, I hooked up my Amp Meter in-line with my positive terminal. (Under Load)
My 1700 mAh Battery Pack read (1.5 Amps) Under Load while it was running.
The battery was slightly discharged, so they are pretty accurate readings.
I have cleared it up on my Web Site as well. ;) I just wanted to keep it easy for the non-techies... ;)
When you see the video I will place on-line with a small battery powering 2 - 400 Watt Turbines, you will know for sure I am on something.
I will have a video on-line probably within a week. The US Department of Energy is checking it out as well.
The energy is created the same way a Hurricane creates mass amounts of energy from Turbulent Air-flow. I also added another pic on-line in Prototype 3 Conclusion Section.
If I would have chosen the 24 or 48 Volt Turbines instead of the 12 Volt, the numbers would be much higher... ;)
Believe me, this project will not go away anytime soon. It is so simple, yet complex....
Anyone is free to build any 3 prototypes, you will receive the same results... Probably better results.
Have a wonderful day and keep checking the site from time to time.
Best Regards,
Robert ;)
: Hello !
: Nice site you have got there.
: Fun and int. to read.
: I have one question for you....
: After reading you site, I wonder :
: How did you measure the input power ?
: I read :
: "I used an ? volt(can`t remember) 1,7 A battery..."
: Since I am educated in electronics I usually am used to other terms...
: Like : I used an 1,7 Ah battery, and has nothing to do with input power...
: Did you measure 1,7 A at the input, or did you just read the 1,7 Ah that is typed on the battery ?
: From reading you site, it seems like you did the last...
: Please explain, (better change the text on the WEB, if you did otherwise).
: If you measured 1,7 A on the input, I am int. in your project !
: Best
: Øystein Rustad
: : I have a new Perpetual Motion theory and explain in detail how this might be a possible solution for the worlds energy crisis.
: : Please visit the Web Site below to see something that is pretty neat!
: : http://www.experiment34.com/
: : Have a wonderful night,
: : Robert ;)
