PS
Posted by RW (66.177.116.68) on September 29, 2002 at 12:39:45:
In Reply to: Re: Experiment 34 Perpetual Motion theory posted by RW on September 29, 2002 at 12:22:42:
I also wanted to share this with everyone as well. Another thing you won't see on the Web Site is that I heard something very interesting.
I believe it was the "Over-unity Echo Frequency" or something no one ever heard before. At this point, I am not exactly sure what it was but will try to explain.
Reading about me, you would probably expect me to plug this into itself and start it up somehow to see what happens. That's exactly what I did. That would be very easy if I had two electric yard blowers and run the turbulent air through the openings of the front-ducted fans.
I knew it probably wouldn't run itself because of the power conversion factors on this particular prototype. But I wanted to try it anyway.
That's exactly what I did. I bought two blowers and I started by blowing them through the ducted fan openings only. It worked great, lots of output power, and just the regular noise you would normally hear with 2 blowers operating. A little noisy but normal...
Now, when I hooked the Output of my Machine to its input and forced air through the 2 front openings, via yard blowers, it started the unit and all the sudden, I heard the strangest and unique sounds.
It was unlike anything I have ever heard. A "high pitched echo effect" that sounded like it wanted to run out of control but couldn't.
Every time I tried it, it did the same thing. It almost sounded like jet but one nobody has ever heard.
I do not know what it was; however, I believe it is the Over-unity Effect. (Not really sure though) The Chargeing Turbines I am using are not even for this type of experiment but they have high output current. See, when the load peeks at 12 volts, the Wind Turbine regulator measures the voltage and current and the Turbines lock the breaks and slow it down so it doesn't overcharge the batteries. (Of course, thats why I have to eliminate the regulators and start with raw power because I do not want it to slow down)
I believe the unit was trying to keep gaining momentum and the internal regulators were slowing it down as it reached 12 volts. As it suddenly dropped, it tried to pick itself back up again. When it reached the 12 Volt mark again, the process repeated. Thus causing a "high pitched echo effect".
Anyway, thats what I think it was&. I believe without the internal regulators it has, and without custom regulators built for this application, doing the same test would make the generator spin out of control until it caught on fire.
Now that would be something.
I am just an amature Inventor and I believe I have something that needs to be taken to the next level. The only way to prove or disprove this theory is to have a team of Engineers to build one with all their resources.
The air enclosures are one of the most important elements to the success of the project. By carefully creating an enclosed circular air chamber around each turbine charger, you are actually recycling the turbulent airflow and using the same airflow multiple times.
The reason this circular motion works is because air is the one element that can stop and start and never be in a state lower than its original form. In other words, lets say we had circular tubing enclosed air chamber with openings where something can be forced through the openings and start moving in a fast circular motion.
If we take something other than air and force it through the air chamber it will eventually slow down to the point where the new object collides with it and causes a chain reaction of constant slowing down. For example, if we forced ball bearings through the opening at a rate of one ball bearing per second, the first ball bearing would shoot through the tube and rotate until it slowed down to a steady stop.
That's why mechanical Perpetual Motion machines are difficult to get to work.
When the next ball bearing in forced through the tube at the same rate, the second ball bearing would be going at a faster rate than the first one and will eventually collide with the first one, thus getting nowhere fast. will always help itself move faster and faster because the state of X will never drop below itself.. The possible structural and functional variations of the Air Enclosures are unlimited as well.
Thanks for reading my information,
Robert ;)
