Re: Gill Simo's Ideas
Posted by Steve (161.114.1.184) on November 07, 2002 at 19:18:08:
In Reply to: Re: Gill Simo's Ideas posted by Vector Viper on November 06, 2002 at 00:43:20:
Thanks for getting those up. Great reading, good Ideas. I think we need to work in every direction conceivable, and some that are not. I've been taking some of the translations given a few posts back and trying to read them as literaly as possible, as Gill suggests. Not to be a spoil sport or anything, I just thought I would bring up some quotes and points of things that I have been thinking on.
quotes from translations in earlier posts:
1: 'around the firmly placed horizontal axis is a rotating disc (or lower cylinder) which resembles a grindstone. This disc can be called the principle piece of my machine.' Obviously for the kinetic energy provided from the mass of the flywheel, which can be added to any wheel.
2: Accounts say that the wheel was always off balance or heavy on one side for the single directional wheel. Now this is hard to explain, so I'll try my best ;) Do they mean off balance when the wheel is tipped over like a dinner plate, suggessting that the weights in the wheel are farther to the rim on a side, or do they mean if it were standing on edge, like a coin, it would always tip to the left to fall flat.
3: {the axle pins}'provide the rotational motion of the whole vertically suspended wheel through application of pendula' I read: {the axle} provides rotational motion of the vertical wheel via pendulums. About the same, but less trash to confuse.
4: If the above were true, and the dual directional wheels had 2 cages, one on either side, then they would not be out of balance as such. The hard part is telling when Bessler is talking about which wheel. I think alot of people loose site of the fact he had wheels that went either direction, I think it was based off of the same design. And the single directional always tried to move on it's own, thus I've learned anything you have to push or ' start ' I tend to give less thought; Unless it can be modified to always have an over balance in one direction, and can be modified back to need a push in either direction.. sound familiar? Currently I'm just trying to focus on the single directional. Why try to design the body of a car when all you really want is the engine.
5: 'coordinated with one another so that they not only never again reach an equilibrium.' Several places in Gill's design will definitly reach an equilibrium.
6: {'essential constituent parts'of the wheel have an}'admirably fast swing to move and drive on the axis of their vortices loads that are vertically applied from the outside' I looked up 'vortice' since I was unsure of what he meant. It's just the force of motion pushing mass to the outside, like a whirlpool. All I'll say is: think of the little bent arms that he shows in his pictures attatched to the pendulums, then spin it; what's it look like.. A vortice or whirlpool. The 'vertically applied from the outside' is just a refrence to Gravity IMHO.
What I get from all this is that there are pendulums swinging quickly inside the wheel, resting on a vortice, in a pre-defined path that are always out of the center of gravity when placed against one another, with a flywheel in the center/side of the housing. Currently I'm working on a wheel that fits all these criteria, should only go in one direction unless another is placed to the opposite side of the flywheel. The pendulums swing up and down, but they think they are going side to side, constantly shifting the COG on the vortice. Oh yea, and the weights apply their weight at 90 degrees, strait onto the axle, not around the rim.
Sorry for the rant, I kinda got going. I love reading all of these great Ideas, I've always thought that there was more than one way to do this.
I'll leave off with one of my favorite parts of the translations:
'one of the best known implements for mechanical power, namely, a true circular wheel which rotates about its central axis.'
: : Hey I wanted to let everyone know that I just posted a bunch of new material from Gill Simo, including a p
