Re: Open Question To Group On Heat
Posted by Øystein Rustad (213.145.185.102) on December 19, 2002 at 10:58:42:
In Reply to: Re: Open Question To Group On Heat posted by Bob P on December 19, 2002 at 05:57:40:
By the way :
A conservation problem may though occour IF we find out that the (possible) Ether flow will not be reduced by a gravitywheel harnessing the Ether flow....
Did you know that gravity can be proven by Einsteins equations to be Etherflow in towards masses ?
And the derived equation
(from Einsteins equations for time delay)
for etherflow will be :
Ether Velocity in towards a mass = (2GM/r)^1/2
And it will be the same number and formula as for to calculate Escape velocity for a planet !!
(If it interests you ?, I can explain why ! )
: Thank you for your interesting thought.
: Perhaps we need to look at gravity in the same way we look at other energies, such as light (electromagnetic).
: An example:
: If we cover the ground with a solar panel, the light/heat (both electromagnetic energies of different frequencies) will not reach the earth.
: However, the electricity generated by the panel can still be used to do useful work, if we want it to (e.g. drive an electric motor). The First Law still holds true.
: Perhaps we need to look at a Bessler-type wheel as having the potential to also extract energy instead of just letting the gravitational energy "fall" on the earth. (I realise that scientists will laugh at this idea).
