Re: Open Question To Group On Heat
Posted by Østein Rustad (148.122.43.126) on December 21, 2002 at 05:48:30:
In Reply to: Re: Open Question To Group On Heat posted by Scott Ellis on December 19, 2002 at 21:53:26:
: Of course we're interested! As you know, I (for one) have an affinity for ether and push gravity theories... Please go on! ;)
OK :-)
This is my my latest theory involving Einsteins equations to prove Ether as the ultimate unification !
First lats take a look at Einsteins gravity :
Mass warps space/time, thus create gravity !
WHY does mass warp/space and time ?
Einstein says it is because atoms rotate/vibrate slower in the presence of a mass, BUT it is because of the mass` gravityfield the atoms rotate slower. If we think about that, we see that there are something missing, and the statement is a self contradiction.
It is one fact, time dilation (slower rotation of atoms) that is true, but without the cause !
Next, we know that there exsists two formulas for time dilation.
One for gravity and one for velocity.
So the atoms in a mass rotates slower when we move the mass through "empty" space, or place it in a gravityfield.
That means that standing on the Earth is mathematicly equal to travelling at a certain velocity through space !!!!!!!!!!!
BUT to create gravity (inetia)that would be equal to accelerate in the same "empty" space.
SO, if an Ether excisted, it would solve a great deal of problems :
It would mean that a mass` motion relative to the Ether is what causes this "time dilation". It would also make no diff. if the Ether moved or the mass moved through the Ether !!
Inertia and gravity would then be acceleration relative to the Ether. So the solution would then be:
If Mass "consumes" Ether to excist, Ether would flow towards a mass following rougly the inverse square law..
So to the math :
Excerpt from my WEB :
IF there is an Ether flowing in towards all mass, the speed of this flow MUST give an equal time dilation (slowing of electron vortices) as travelling at the same speed through the Ether in "empty space".
So let`s see :
Formula for time dilation for velocity is :
1-( v^2 / c^2 )^1/2
Formula for time dilation in a gravityfield is :
1-(2GM / c^2 R)^1/2
G = the Universal gravity constant = 6,9 * 10^-11
M = Mass of the planet
R = radius from the center of the planet
Now we combine the formulas and we get :
1-( v^2 / c^2 )^1/2 = 1-(2GM / c^2 R)^1/2
We see that everything outside the ( ) are the same and can be removed, and we are left with : 2GM/c^2 r = v^2 / c^2
To get velocity alone we get : v = (2GM/r)^1/2
If we put in the Earths parameters, we get 11,1 Km/sek.
So we can say that :
Ether velocity (in a gravityfield) = (2GM/r)^1/2
This is the same as to calculate Escape velocity for a planet.
It meas that this is the speed a mass must have to escape the gravityfield without adding more energy. Like a shotgun and a bullet. So if the mass have the same speed as the Ether, in opposite direction, it has the same energy state that the Ether has and the energy is enough to escape the field !!!!!!!
Then Photons = Etheric waves, red / blue shift due to gravity will follow the same above formulas and enables bending of light, and black holes, it also solves the speed of gravity "ridle".(and exclude time travel) Time can be thought of as absolute (matter of personal view) Absolute time is relative to zero Etherflow.
The denisty component of the Ether in the universe will change because of this and may solve the Cosmic red-shift "problem".
And we can finally dismiss the stupid BIG BANG and expanding universe !
Øystein
