Re: Now what?
Posted by John (207.150.66.33) on February 08, 2002 at 14:13:03:
In Reply to: Re: Now what? posted by Christopher on January 22, 2002 at 12:30:43:
Thanks for the info. Like yourself I started out tinkering and then after a few years I decided to "knock myself out". From wakeup until 3 o'clock in the morning thinking of and designing of "the" elusive wheel for about three years. I had quit over-partying(a nasty habit) and it is amazing how many interesting weight arrangements you can come up with-that are all perfectly balanced!-with a newfound clarity. You could work on this every day for the rest of your life and not come up with it. John John,
: I have been tinkering with designs for a long time too and have, on several occasions, come up with one that I just knew would work. Unfortunately, after applying all the proper mathematical calculations, it simply balanced. I can't tell you how many times I've arived at that same stupid 22.5 degrees and wanted to tear up my notebooks.
: I also have just recently arrived at a design that, once again, I know will work (did the math this time and got > 22.5 degrees!), but until I build a prototype it doesn't mean anything.
: There have been people claiming to have 'the answer' for hundreds of years but 'the proof is in the pudding.'
: If you wish to gift this idea to the world then your next step is to post it in detail on this discussion board.
: If you would prefer to make an attempt at marketing your idea then I suggest that you:
: - Refer to the following web site for initial information.
: http://web.mit.edu/invent/www/handbook/chapter07.html
: Don't forget to use non-disclosure agreements between you and anyone you trust with your idea.
: - Create CAD drawings of a prototype
: - Use the CAD measurements to doublecheck your CG, inertial calculations, etc. I've developed Excel spreadsheets for this because I got tired of writing out those long CG formulas :-)
: - Locate a local machine shop or plastics mold injection shop and provide them with a set of your CAD drawings so they can build part(s) you need that are otherwise unavailable.
: http://www.performanceplastics.com/
: (just an example, I don't work for them)
: - Build a working prototype
: - Go to http://www.randi.org/ and apply to take on his challenge. If you prove to him it's real you'll win a cool million that you can use to seed your new business.
: - Once you have a working model and the million you can patent your idea. Normally the patent office won't even accept patent applications that remotely resemble PM machines unless you have a working model
: http://www.uspto.gov/web/offices/pac/doc/general (search for 'perpetual motion')
: - Collect your Nobel Prize for Science
: Just a note: I will be pretty upset if you get yours done before mine so... take you time :-)
