Re: CG Path
Posted by Christopher (208.143.232.66) on March 08, 2002 at 10:01:19:
In Reply to: Re: CG Path posted by Scott Ellis on March 08, 2002 at 01:53:12:
Scott,
The weights are shifted by gravity. There are (what I call) S weights and M weights. The S weights (shift weights) move downward, pulled by gravity, and are connected to the M weights (main weights) which comprise the bulk of the mass for the entire system. It's the M weights that throw the c.o.g. so far to the right. Don't want to go into too much more detail until I can come closer to solidly verifying this mathematically. Well, actually, I have verified it mathematically as much as I possibly can without building a working model so I'm pretty sure my next step is just that... to build one. I posted this same question on Keelynet and to an aquaintance from the Delphi Pollution Free Energy forum. They supplied me with additional hints and formulas and so far everyhting continues to unbalance (yikes!) Now I just need to do up some CAD drawings and get this bugger built!
BTW, the formulas supplied were basically torque formulas and verification of my original calculations. Other than that everyone has been fairly quiet, which is okay... I'd rather that then a pack of pitbulls trying to tear me apart telling me this is impossible. :-)
Thanks Scott!
: I am probably not your intended respondent, since I am not "fluent" in physics related math.
: However, I do appreciate your post and I have a question for you. You say that the machine has "trigger points" that cause the masses to shift. Shifting weights requires energy, so where is that energy coming from? It is easy enough to shift weights around in a scheme, the trick is making that weight shift actually result in "re-guaging" the mechanism for the next weight shift to occur.
: If you can address this issue, maybe you will get a response from someone more able than myself!
: -Scott
: : I have something that I'd like to run past anyone who is fluent
: : in physics related math...
: : I am toying with a wheel that has "trigger points" every 45 degrees.
: : When a "trigger point" (TP) is reached weights shift and the
: : Center of Gravity (CG) moves to the right. This shift unbalances
: : the wheel and causes it to turn, hopefully, far enough to reach
: : the next TP or beyond.
: : I have calculated the CG at 7 points of rotation between 0 and 45
: : degrees (more than that is not necessary since the CG returns to
: : the 0 x,y location if we make it to the next TP. In other words,
: : the CG path repeats every 45 degrees of rotation.
: : Assuming (0,0) is the center of the wheel, the total of all the
: : weights is approx. 60 lbs, the wheel radius is 50 inches,
: : and the wheel is rotating clockwise, would the following CG path
: : indicate OU?
: : Degree of Rot. CGX CGY Theta
: : 0 2.82 -2.82 45.00
: : 7.5 2.43 -3.16 37.50
: : 15 1.99 -3.45 30.00
: : 22.5 1.53 -3.68 22.50
: : 30 0.73 -3.46 11.93
: : 37.5 0.03 -3.10 0.52
: : 45 -0.56 -2.63 -12.12
: : It looks to me like there are 5 points to the right of center
: : where speed/rotation would be increased, one point in the center
: : which would probably have little effect, and one point to the left
: : to slow it down. The start and end Y locations are not even that
: : different from one another so it's not like the CG has to climb
: : some gigantic hill at the end.
: : Seems straightforward to me but I MUST be missing something...
