Re: Gyros (my tippe top extension)
Posted by Jonathan (68.14.212.239) on October 19, 2003 at 03:52:00:
In Reply to: Re: Gyros (my tippe top extension) posted by ovyyus on October 18, 2003 at 23:44:31:
Well that explains why it never occured to me before. I don't know where I read it but somewhere it said that the center of the mass was closer to the peg tip than the center of the hemisphere, which didn't make sense, it should be vice versa. But given what you've said, I guess it is vice versa. However that is not what this thread is about. I can't really say what it is about until my picture is posted because it's hard to describe.
: The 'tippe top' does not raise its own centre of mass without expending energy to do so - ie: lifting its mass costs RPM.
: Gyro RPM can transform into precessional torque and visa-versa. Laithwaite demonstrationed the lifting of heavy spinning gyros high above his head with little effort, but the energy for the lift is at the expense of rotational momentum. No free lunch, but very interesting mechanics.
: On the other hand, a gyro can be driven to higher RPM by applying timed precessional torque, as with the "powerball" hand held gyro excerciser/toy. Check out the link - http://www.powerballs.com/what.html - it's an interesting and educational device. Again, the energy equation perfectly balances. Fascinating none the less.
: Regards, ovyyus
: : I too have been interested by gyros, and have noticed an interesting effect. If a nonspinning gyro is hung from a string, it just sits there. If one spins it fast and lifts its axle up to horizontal, it won't fall, but willgo around from precession. However, if one connects another string from the other end of the axle to the point of suspension so that the axle and original string have a 90 degree angle AND the gyro is not spinning, the whole thing tilts so that the center of mass is below the suspension point. So why does this not happen when spinning? I'll have to send a picture to scott...
