Triplock wrote:Fletcher
Saying where the excess energy comes from should be easy to do, even without any scientific laws governing that outcome.
No, it isn't easy to do at all - in fact it's impossible to do, using current physics & the laws that govern their mathematical expression - everything folds back in on itself & intertwines with no known loopholes to exploit.
If you think it is easy, "even without (using) any scientific laws governing that outcome" then apply that reasoning to your own designs including any that purportedly use weight imbalance to sustain rotation - the laws do not allow it, & the math expressions of those laws don't have any wiggle room, unless you can demonstrate a symmetry break to drive the bus thru.
Triplock wrote:What I mean by that is your hypothesis just a leap of faith that makes A+B=C or does it have foundation.
I hope that you don't mind being under scrutiny from an idiot like me. By asking, I also learn.
Actually I'm saying the current laws say A + B = C - I'm also saying that in order to get excess KE & momentum then the above equation is invalid & a new one must be substituted.
The foundation I'm am using is sim results for a RBGS - in my case I built half RBGS's in pendulum form (see previous posts) - gravity caused the pendulum to fall & accelerate etc - regardless of where the mass on the horizontal beam was located (i.e. how far from the COR) the swing period remained identical, which means that the pendulum MOI was unchanged.
I.E. the RBGS is a torque equalizing mechanism AND mitigates the effects of mass placement distance form COR effecting the MOI of the RBGS, as compared to other mechanical arrangements.
Triplock wrote:So the net torque to rim, after transference , does what ?
Turns the RB, Yes laterally slides the mass Yes , spins up flail Yes ? Basically, list what you're asking the outer rim to accomplish with x amount of energy , even if just overcoming friction. You then can see what you have in each hand. I think it's a wash, although an ingenious wash.
Thanks mate
And therein lies the problem of understanding Chris - it is not constrained by the COE laws, so I have little interest in how much energy it starts with, just how much it has at the end - you've heard the saying "it's not the destination but the journey that's important" - that applies here - by following steps, of which one involves the use of a MOI mitigating mechanism, then it appears possible to break the entanglement of symmetry which ordinarily limits us to the COE outcome you speak of.
IOW's it seems hypothetically plausible to consecutively add the componet vectors to some degree, or to put it another way, to gain more momentum transfer (& system KE gain) from parts interacting than has previously been thought possible.
That's the theory - do you own experiments with the RBGS to test the foundations.
