Flip-flop wheel...
iacob alex
Flip-flop wheel...
Post by iacob alex »
.....at : http://www.geocities.ws/iacob_alex/Some ... ext009.jpg
Here,you can play the "switching spur" (short arm-long arm), as you like...
Al_ex
iacob alex
re: Flip-flop wheel...
.....can be considered a (simplified) "derivative" of an "old" topic (2009),namely "MT13 digest...".
As a matter of fact , we play variable/oscillatory leverage , due to gravity (fall) unbalance and the interplay with inertia.
Al_ex
iacob alex
iacob alex
.....with three arms/spokes ...intended to (self...) rolling "on the spot " , at :
www.geocities.ws/iacob_alex/Some_Drafts/text011.jpg
The idea is to maintain a continuous gravity unbalance ( torque difference ) , on the same side of the fulcrum.
Al_ex
iacob alex
.....as a very old proposal of an automatist and clockmaker ( Henri Maillardet ) , at : www.energythic.com/view.php?node=264
He plays the variable arm in two points , due to the ( self ) triggering action of gravity.
A simplified design , at :
www.geocities.ws/iacob_alex/Some_Drafts/text022.JPG
Al_ex
iacob alex
.....as a possible gravity self-powered "wheel" (as a matter of fact ... a swinging-rotating leverage...) , if we associate two proposals ( Maillardet's elementary "masselotte"/variable arm and Milkovic's double oscillatory/swinging system ) into :
www.geocities.ws/iacob_alex/Some_Drafts/text030.jpg
To copy others is necessary...when insist on yourself , but never assume.
Al_ex
Hi iacob alex;
i can agree on
As a basic, but you must create a closed loop.
So a carrier has to carry and include the Milkovic's double oscillatory/swinging system.
Makes it more complex in the movment, because the swingings had to be syncronized.
But the way is clear.
iacob alex
.....as a mechanical "counterpart" of an electronic device ( see Merriam-Webster dictionary...) , capabile of assuming two stabile states , at :
www.geocities.ws/iacob_alex/Some_Drafts/text031.jpg
.....possibly as a gravity continuous oscillatory unbalanced leverage , due a torque difference on the same side of the fulcrum (if tested ?!...).
This proposal is MT 13 digest/nonredundant representation ( see the so-old Middle Ages gravity wheel) and Milkovic's double oscillatory system ( see the so-old shadoof).
Al_ex
