Hi niki123,
But what is the relation between your post and the fact that any hydrogen-generating electrolyzer can be considered as an electric heater which has efficiency greater than 1?
George
George
Any reasonable and competent (only!) advices, recommendations and points of view related to our conception? I am not spamming, I am only trying to form a qualified discussion.
George
George
I will repeat my last post.
Obviously new technology conceptions win public recognition with difficulty.
George
George
There is still no answer? Does this mean that every forum's member agrees that every standard hydrogen-generating electrolyzer is practically a simple electric heater, which has efficiency greater than 1?
Obviuosly there aren't any experts in electric engineering in this forum. Otherwise we cannot explain to ourselves this deep silence and this absolute lack of of constructive and reasonable discussion.
George
George
Any opinions, recommendations, positive critique related to our new electric heater of efficiency bigger than 1?
An interesting discussion occurs in overunity.com. This discussion is related to our zigzag conception. The title of the topic is just the same, that is, "A simple electric heater, which has efficiency greater than 1". Please have a look at this discussion, if you like. It would be interesting if you share your opinions about this discussion.
Hi everyone,
Any opinions related to the discussion in overunity.com? This discussion is related to the same topic. The title of the topic is just the same, that is, "A simple electric heater, which has efficiency greater than 1".
George1
George1
Hi everyone,
1) THEORY and PRACTICE! Two words! It is a SIMPLE OBVIOUS FACT that if a certain scientific THEORY is correct, then the related PRACTICE has to be also correct. And if you have any objections against this SIMPLE OBVIOUS FACT, then you have some mental problems for sure.
2) In overunity.com and in besslerwheel.com/forum we (our team) released ABSOLUTELY FREE two pieces of THEORETICAL research, whose titles are " IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION MACHINE?" and "A SIMPLE ELECTRIC HEATER, WHICH HAS EFFICIENCY GREATER THAN 1", respectively. For these two pieces of scientific THEORETICAL research is valid the statement in the previous item 1.
3) These two pieces of scientific THEORETICAL research (mentioned in the above item 2) unambiguously show (no serious and reasonable THEORETICAL objections within a period of two years in overunity.com and in besslerwheel.com/forum) that the law of conservation of energy and the law of coservation of linear momentum are not always correct. But there is nothing special, tragic and disturbing in this fact as any rule/law has its exceptions.
4) Our third piece of technology is a new electric technology which increases many times (at least twice as a minimum) the distance traveled by any standard electric vehicle on a single charge.
5) Our new electric technology has both THEORY and PRACTICE. In other words, we have a WORKING PROTOTYPE which perfectly confirms the correctness of the theoretical concept on which is based the principle of operation of our new electric technology. The latter is practically ready for production on a large industrial scale.
6) The secret of our new electric technology however is NOT FREE. It costs already 40,000,000 (forty) million dollars and this price will further rise if our first two pieces of THEORETICAL research (mentioned in the above item 2) do not win public recognition in the nearest future.
7) These 40,000,000 (forty) million dollars will be used mainly for charity and only a small part of this money will be used for some R&D work.
8) We (our team) are looking for buyers of the secret of our new electric technology (and of our next 7 (seven) inventions and technology innovations).
George1
George1
George1
George1
- MrTim
So...
Have you (or anybody else) built a duplicate machine that operates exactly as the original?
This topic (and related) should probably be moved to the fraud forum.
To Mr. Tim
Duplicate machine of the working prototype? No.
To ovyyus.
You are simply an ignorant in the field of electric engineering and in the field of electrochemistry. I cannot discuss the matter with you. Where do you find any fraud?
Hi everyone,
1) "IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION MACHINE?" and "A SIMPLE ELECTRIC HEATER, WHICH HAS EFFICIENCY GREATER THAN 1" up-to-now discussions unambiguously show that the law of conservation of energy and the law of conservation of linear momentum are not always correct. But there is nothing special, tragic and disturbing in this fact as any rule/law has its exceptions. That's all.
2) We are selling our next 8 (eight) inventions. As a first step we are selling a new electric technology, which increases many times (at least twice as a minimum) the distance traveled by any standard electric vehicle on a single charge. Actually we are selling a WORKING PROTOTYPE together with a full description of its principle of operation.
3) Our new electric technology can be successfully used in any battery-based electric device. For example if our new electric technology is used in an ordinary standard electric torch, then its working hours would be increased many times (at least twice as a minimum) preserving at the same time its standard rated intensity of light. So the electric torch industry could realize a good financial jump by using our new electric technology. (Please note that in many emergency cases the duration and the intensity of an electric torch light are of vital importance for saving of human lives for example.)
4) We have some ideas for how to sell our new electric technology. We are negotiating now with some big companies. At the same time however we are open for collaboration. If some member of this forum suggests a smart method of selling of our new electric technology and/or takes part in the selling process, then he/she would firstly earn good money and secondly, he/she would indirectly contribute to our charity causes.
George1
George1
