path_finder's Overbalanced wheel
re: path_finder's Overbalanced wheel
I think OB can cause rotation as long as it doesn't persist. OB is the farther weight falling the greatest distance.
jonnynet
Post by jonnynet »
Ok, then I seem to simply not use the term in a proper context, at least in another one. It's not a problem. Will continue to look for a mechanism to demonstrate the behaviour.
Sorry Jonnynet. My statement was disagreeing with your entire conclusion. I do not believe this method will work at all, even with a "virtual"support. The reason is: the weight needs to fall (or be felt to fall) more than it is lifted to power rotation. This does not do that.
veproject1
Post by veproject1 »
The other Overbalanced wheel model
https://www.youtube.com/watch?v=4Y-eDX0y0pc
Impressive, but it needs some help to rotate
jonnynet
Re: re: path_finder's Overbalanced wheel
Post by jonnynet »
Tarsier79 wrote:Sorry Jonnynet. My statement was disagreeing with your entire conclusion. I do not believe this method will work at all, even with a "virtual"support. The reason is: the weight needs to fall (or be felt to fall) more than it is lifted to power rotation. This does not do that.
That's totally fine, Tarsier. Everyone can and should have their own belief. The most important thing is still to continue research and to share.
