What are the consequences of the reputation system?
Members with a high reputation rating will carry more respect and influence in the community. Members with a low reputation are likely to be ignored, disregarded, or flamed by other members. As a rule of thumb, once a member receives the reputation "This member should be banned," they will have one month to improve their rating or be automatically banned from the forum. The site admin reserves the right to use his own discretion in applying these guidelines to individual cases.
Is a bad reputation the only thing that can get a user banned?
No. If you make the Administrator angry enough, or violate the terms of use agreement in any way, you may be permanently banned regardless of your reputation.
My original post questions were never addressed?me wrote: Using Eccentrically1 as a wedge, let's see what he has to say:E1 wrote: How many more steps must we endure? I'm sure this is a waste of time. Once the experiment is in space, there aren't any means to initiate motion; it's effectively isolated from its environment. The zigzag concept is nullified.
E1 wrote:
It isn't a reactionless drive or a PMM. How does the blue component start moving? You'd have to include that in your theory. How does the blue component get back through the segment S to reset for another cycle without cancelling the initial motion? Also important to your theory.
And then:
E1 wrote:
this example of two machines, one with a frictive linear section, and the other with a non-frictive zigzag channel.
The claim is the reactive forces from the black component would be the same in both machines (Fc = F'c), because the zigzag channel would generate resistance without thermal losses, and proving your claim. In the thought experiment, the ideal conditions stated there were no electromagnetic forces. (4th paragraph)
https://mypicxbg.files.wordpress.com/20 ... _01-12.pdf
Given that, the experiment fails at that step. There would be no resistance in either machine if there are no EM forces present. Both blue components would move through without encountering resistance. The linear s section would behave as though it were a zigzag channel, i.e., without friction.
The other inconsistency I note is in the above paper, the black component is allowed to move. In the 3rd link, containing the now-infamous question, the black component isn't allowed to move.
Given just these two issues with your thought experiment (there are others),
the answer to your question is no, you can't choose a suitable combination of (a) magnitude of force of friction, (b) length of segments s and (c) number and shape of zigzags, for which Fc = F'c, Fc > 0, F'c > 0, d = d', d > 0 and d' > 0?"
Given your responses it would seem that you are the one who doesn't understand theoretical or applied mechanics.
The clock on your reputation is ticking, George1.ME wrote:Was about to reply too, but agreed with ecc1.
