Because this post happened to fall on a new page I'll add your text as a courtesy for avoiding unnecessary page swaps.
George1 wrote:Hi ME,
Thank you for your reply.
But you are not reading carefully my posts.
1) Firstly, we are not talking for the present for V', V", Vi and Vr at all! Please pay special attention to this fact!
2) Secondly, please have a look again at the link https://www.knowledgeuniverseonline.com ... -plane.php
3) Thirdly, R is not equal to mg, this is clear. We are not argueing about this fact.
4) Fourthly, G = mg = weight of the body.
4) Fifthly, if you accept the validity the considerations in the above link, then you have to accept the validity of the equality G = - G. The body exerts a vertical downward force G on the inclined plane. At the same time however the inclined plane on its behalf exerts a vertical upward force -G on the body. Besides G=-G, that is, the two forces G and -G are opposite in direction and equal in magnitude.Do you accept the validity of the considerations in this item 4?
George
1. Firstly: Please read again. 'V, Vi etc' was a side note... To specifically repeat: Letters do not tell the story, they indicate.
2. Secondly: I did. I did not invent this 'R'. The "R", of Reaction force, may be the cause of your confusion (I don't know).
3. Thirdly: This is related to the first.... This letter R equates to the Normal force. Which is indeed not mg, there is no argument other than you making it a third item.
4. Fourthly: yes
5. Fiftly: Nonsense!
- 5.1. Fiftly-dot-firstly: Mathematically G = -G is only valid when G=0. This is clearly not the case!!
5.2. Fiftly-dot-Secondly: G is non-zero and directed straight down, so yes I agree that "The body exerts a vertical downward force G on the inclined plane."
5.3. Fiftly-dot-Thirdly: The plane does not, I repeat DOES NOT, "exerts a vertical upward force -G on the body".- 5.3.1. Fiftly-dot-Thirdly-dot-Firstly: That's where this 'R' comes in.
5.3.2. Fiftly-dot-Thirdly-dot-Secondly: We better name it 'N'.
5.3.3. Fiftly-dot-Thirdly-dot-Thirdly: It is the N of NORMAL-force of the plane and is provided by the plane because that plane is a sturdy one and not, for example, made out of foam.
5.3.4. Fiftly-dot-Thirdly-dot-Fourthly: This Normal force is perpendicular to the plane. Thus at an angle θ
5.3.5. Fiftly-dot-Thirdly-dot-Fiftly: This Normal force has a magnitude of mg·Cos(θ).
5.3.6. Fiftly-dot-Thirdly-dot-Sixtly: Please have a look again at the link https://www.knowledgeuniverseonline.com ... -plane.php
5.3.7. Fiftly-dot-Thirdly-dot-Sevently: ... it tells you the same value when you look at the vector indicated with 'R', which is actually the Normal-force.
5.5. Fiftly-dot-Fiftly: To give a counter-advice for us not being "experts in theoretical and applied mechanic": Please learn some basic physics. - 5.3.1. Fiftly-dot-Thirdly-dot-Firstly: That's where this 'R' comes in.
Something to consider:
- When G would be countered in total ("G = -G" as you like to put it), then which force would be responsible for accelerating an object down a slope?
Lesson to learn, or a hint (whichever you like):
- When θ=0 then the plane is a flat plane, like a TABLE. On this FLAT HORIZONTAL TABLE the Gravitational force is countered IN TOTAL by the Normal force of the table. Now that object will not go anywhere, and we may only now put is as "G = -G".
