PROCESS RESTART
Re: PROCESS RESTART
Ci dessous:
Roue avec le principe des verrous.
Roue avec mecanismes plus stables, deux galets dans la glissière.
A suivre
Below:
Wheel with the principle of locks.
Wheel with more stable mechanisms, two rollers in the slide.
To follow
A suivre
Below:
To follow
Re: PROCESS RESTART
weights at the same velocity as axle but vary their speed. Cool design.
Radial scissor jacks are excellent for keeping a mass in a given moment wrt a point of rotation. Find out how to drive them and . . . . . . . . . . :)
only the shadow knows
Re: PROCESS RESTART
La torture avec Algodoo!!!
La dernière mouture ci jointe.
je passe à la construction de deux éléments opposés pour vérification de fonctionnement.
A suivre!
Torture with Algodoo!!
The last version attached.
I move on to the construction of two opposite elements for verification of operation.
To follow!
A suivre!
To follow!
Re: PROCESS RESTART
@ Ombre, your system leaves dreaming, courage for the realization it is not very easy.
A++
A++
Not everything I present is functional, but a surprise can't be completely ruled out. Thank you very much.
Re: PROCESS RESTART
Une petite dernière un peut tordue en attendant d'aller à l'atelier.
One last one can be twisted while waiting to go to the workshop.
Lien vidéo
https://youtu.be/j7cmmz1W7mg
Lien vidéo
- EXCENTRIQUE2.zip
- (314.37 KiB) Downloaded 84 times
Re: PROCESS RESTART
My guess would be that the bearing holding the main wheel, is being forced out of it's position by the forces in play. We can see the outer wheel pulling away and returning to the upper wheel on the left. The eccentricity of the bearing creates a spring effect, where the programme pulls the whole thing back to centralise the bearing, and this creates a force that doesn't actually exist.
We need to invent Algodoo bearings, et le tour est joué.
Re: PROCESS RESTART
Robinhood,
Je suis d'accord avec vous sur la fiabilité d'Agodoo, il n'y a pas que les roulements à mettre en cause!
Quant a la possibilité de réaliser des roulements de type Algodoo je pense que c'est possible si on analyse la répétition de la déformation.
En bref cela démontre qu'il faut aller plus loin qu'une simple simulation pour prétendre à des résultats, néanmoins cela reste une bonne approche avant d'aller plus loin dans un projet.
Robinhood,
I agree with you on the reliability of Agodoo, there are more than just bearings to question!
As for the possibility of making bearings of the Algodoo type, I think it is possible if we analyze the repetition of the deformation.
In short, it shows that you have to go further than a simple simulation to claim results, but it is still a good approach before going further in a project.
Robinhood,
Re: PROCESS RESTART
J'ai remplacé les galets dans les glissières par de simples axes fixes pour éliminer les roulements.
Le résultat est plus stable et la rotation est identique.
On peut suggérer que la carte graphique du PC a du mal à suivre le calculateur d'Algodoo.
I replaced the rollers in the slides with simple fixed axles to eliminate bearings.
The result is more stable and the rotation is the same.
It may be suggested that the PC graphics card has difficulty following the Algodoo calculator.
Re: PROCESS RESTART
J'ai remplacé le roulement central par une bague métallique a noyau élastique.
la roue tourne toujours mais avec moins de puissance en sortie.
I replaced the central bearing with a metal ring with an elastic core.
The wheel still rotates but with less output power.
Re: PROCESS RESTART
J'ai du difficulté avec les cordes/chaines, je pense que c'est a cause du carte graphique du pc. Es ce que tu a le même problème?
I have difficulty with chains/ropes which i have put down to the graphics card of my pc. Do you have similar problems?
Re: PROCESS RESTART
C'est abominable et prise de tête, il faut prévoir un tendeur.
Expose moi ton problème et je te donne une solution si c'est dans mes capacités.
It is abominable and heady, you have to provide a tensioner.
Tell me your problem and I’ll give you a solution if it’s in my ability.
Re: PROCESS RESTART
Avancement de le roue grenouille:
Test avant réalisation le mécanisme dans son ensemble fonctione corectement comme je le résentais.
Un bémol quand même j'azi mis des proportions de ciseaux pour pouvoir asser sous mon plafond et si je reproduit graphiquement ce design, je n'obtien drais pas le déséquilibre souhaité.
je dois donc revoir ma copie avec de nouvelles proportion que j'ai définies.
A suivre pour cette roue!!
je rassemble entre temps le matériel pour tester la roue excentrique, j'ai les galets et la couronne extérieure.
Il me reste à trouver le moyeu et les leviers.
De nouveau, suivre pour cette roue!!
Progress of the frog wheel:
Test before performing the mechanism as a whole works in sync as I felt.
A flat still I azi put scissors proportions to be able to slave under my ceiling and if I reproduce this design graphically, I will not get the desired imbalance.
I must therefore review my copy with new proportions that I have defined.
To follow for this wheel!
I gather in the meantime the material to test the eccentric wheel, I have the rollers and the outer crown.
I still have to find the hub and the levers.
Again, follow for this wheel!!
Re: PROCESS RESTART
Elucubrations divers!!!
Miscellaneous elucubrations!!!
Re: PROCESS RESTART
Nice drawings.
What are you going to do next with these ideas?
Re: PROCESS RESTART
Je ferais un test réel pour le dernier il découle du second
le premier je ne suis pas convaincu je testerais peut être sur Algodoo
pour le second, trop sofistiqué pour moi (étanchéité) il déccoule de l'animation sur le site bessler Orffyre.com
J'ai un petit dernier type pince à sucre!!!
I would do a real test for the last one it follows from the second
the first I am not convinced I would test maybe on Algodoo
for the second, too sofistiqué for me (waterproofing) it drops animation on the site bessler Orffyre.com
I have a little last guy sugar tongs!!!
