the gravitational energy converter
Re: the gravitational energy converter
Why is the L-shaped weight the solution ?
The L-shaped weight distributes the force on two points
1. the force on the sub-axle
2. the force on the rim of the hole
Depending on the weight distribution of the l-shaped weight the roller on the rim in the hole will roll upwards to the 4 o'clock position.
So in my experiment the center of mass is shifted to the right.
This is the elemetary function.
Fletcher was so kind to simulate this elementary function in a circus wheel.
So he used this elementary function twice in the circus wheel and received a torque, until the circus wheel received the 12 o'clock position.
When you look at his sim, you see that the rolling weights are orientated to one direction, one is rolling to the center, the other to the rim of the carrier wheel/circus wheel.
They act simultaneously and syncronized.
In the clock of Praque, we have 12 holes and figures.
So repeat the circus wheel with 4,6,8, N*2 holes.
Georg Keunstler wrote:... Depending on the weight distribution of the l-shaped weight the roller on the rim in the hole will roll upwards to the 4 o'clock position.
So in my experiment the center of mass is shifted to the right. ...
Mornin Georg ..
Here is the same circus wheel but this time I adjusted the L lever arm mass and the roller mass to equalize the turning moments ( torque ) at the sub-axle pivot ( 5.00 kg arm mass and 3.57 kg roller mass ) - now the L lever has a tendency to roll on the rim and seek and stay at the 4 o'cl position, if released from either above or below 4 o'cl ..
Result .. the sim is basically stationary as it has no torque - this is what Shadow's original sim showed when turning moments are balanced out .. in my previous sims there was a slight bias ( 5.00 kg each ) which caused the whole wheel to rotate until balance was found ..
Hi Fletcher,
I concentrated the focus on the cylindrical rollers.
This are the weights in the 4 o'clock position.
I have drawn
different length of lever arms
only them now as a weight in the sketch and you will see that the distance to the main axle is different.
L1 is not equal to L2.
Georg,
You have the right idea. The ring and roller never gets bottom heavy. It can provide continuous torque to the wheel and is instantly reversible. However; the roller has to shift continuously. I don't see how oscillations will ever work but, maybe if you can find a better way to do it, you would have a runner-------------------------Sam
Hi Fletcher,
I have drawn different length of leverarms.png only them now as a weight in the sketch and you will see that the distance to the main axle is different.
Hi Georg .. for the L Lever to prefer to stay orientated at the 4 o'cl position then some things have to happen - we know the horizontal distance to both the arm weights and the roller weights to the sub-axle is different - therefore we have to adjust the mass of the arm weight and the roller weight until the L lever is completely balanced ( at the sub-axle ) at the 4 o'cl position ( only the 4 o'cl position ) - IOW's the Turning Moments about the sub-axle are equal ( at 4 o'cl ) i.e. and there is no torque ..
If there are equal turning moments ( no torque / balanced ) at the 4 o'cl position, and the sub-axles are opposite each other at the same radius then they are also balanced ( have no torque ) ..
The result is a perfectly balanced circus-wheel ..
If you change the mass so the turning moments are not equal then you will create a torque bias and the L lever won't come to rest at 4 o'cl but somewhere else where it will be balanced about the sub-axle ..
Balanced Turning Moments ( TMs ) => f1 x d2 = f2 x d1 = 0
Try calculating the TMs at 3 o'cl and 5 o'cl ..
Best ..
Georg .. here is the TMs calculated when the rhs roller weight is double the lhs roller weight ..
I doubled the roller weight on the right hand side compared to the left hand side roller weight - see the rhs L lever move down to near 5 o'cl and stay there - then each pair TMs are equal each side of the sub-axles at those positions ..
So I see it as confirmed that we get the cylindrical rollers always to the 4 o'clock position.
The 4 o'clock position is achieved only with gravity force.
One weight is arranging the other.
In one hole we have therefore an asymmetric force. The gravity force is shifted vertical.
How much it is shifted vertical is depending on our model size.
A hole is representing an endless lever.
a hole is an endless lever
With 2 holes I had drawn before we get 2 different length of levers.
A short lever on the left side of the circus wheel and a long lever on the right side of the circus wheel.
The result is that we have now a permanent torque on the circus wheel.
2 holes are enough to show the principle, but 2*n will be better.
I have choosen 8 holes in my construction.
Here I messure the force on the surface when we change the angle.
Full force of the weights we have in the vertical position, when the cylinder is at 6 o'clock.
The force is less when we increase the angle, when we roll the cylinder to the 4 o`clock position.
force on the surface with different angles
I have prepared also the videos of the messurement under @GeorgKuenstler3108 in youtube.
Here is the full description of the parts and measurements for the construction.
Have a closer look to the L-shaped part with the rolling cylinder at its end.
The L-shaped part is laid on the sub axle, which is an important part of the construction, so that we can apply gravity force to the rolling cylinder.
different lever arms
So we have now Besslers "Verbundenheitsprinzip"
Maybe the better description is "dualitätsprinzip".
Georg, Georg------------listen to me!
I'm afraid, there is little or no weight on the rolling cylinders. It is all concentrated / centered on the sub axles. Which means it will still be balanced. Am I wrong Georg?-----------Sam
Hi Sam,
sorry but you are not right, when the cylindrical weight is in the 6 o'clock position, the full weight of the l-shaped construction is on the rim of this hole.
You see the sub axle as a sub axle as you know axles, but that is not the case here.
A technician will construct the L-shaped construction with an long hole, but I only layed the l-shaped on the axle.
See the difference.
I have opened one side of my test wheel so that you can see the sub-axle and the position of L-shaped weight.
lay on the sub-axle
lay on the sub-axle
Depending of the weight distribution of the l-shaped weight we get an angle, idealy we get the 4 o'clock position.
The L-shaped weight is not fixed on the sub-axle, so we get the force on the rim of this hole.
My basic construction has 8 of this holes it is like a circus wheel X 4.
I need only the internal part with the 8 holes and the support for the demonstration.
4X2 circus wheel
4X2 circus wheel
This parts are now in Bad Karlshafen, when I will be able to travel to this location I will install all 8 l-shaped weights
Hi Sam and @all.
maybe you see now that the L-shaped weight has a roller on the bottom.
The best thing which I had discovered today.
Basic of the movement is an inverse pendulum.
here the link to the video
https://www.facebook.com/reel/919472186829313
l_shaped robot
l_shaped robot
l-shaped robot.png (79.67 KiB) Viewed 8686 times
the source is
Frauenhofer 20250205
frauenhofer 20150205.png (64.82 KiB) Viewed 8686 times
Georg,
I think you have the right idea. The circus wheel is proof of it. Maybe you have it figured out; it's worth a shot. I'm thinking now that just displacing the roller isn't enough. It also has to rotate, rotate and be displaced at the same time. Some how--------------Sam
Hi Sam,
it does exactly that what you are expecting.
A rotation of the cylinders in the hole, and therefore a rotating of the circus wheel.
A rotation in a rotation.
The trick is, that the rolling of the cylinders must be done synchronized,
they act in that way that one cylinder is going to the main axle and the other to the rim.
This is creating an imbalance of the circus wheel, we have an OOB wheel.
It is constant out of balance. And there is no bouncing as everyone is expecting.
The first construction of the Bessler wheel had had also no bouncing.
The knocking/bouncing of the wheel was only heard by the bi-directional wheel.
So this has an different internal mechanism.
This fact is always mixed up, and it has made it difficult to seperate this two mechanism.
Hi Georg,
I like the fundamental idea of it. Not sure of the details of it; the oscillating of the rollers. You should try to turn them, the rollers, faster than what the wheel is turning, as a way to displace them-----------Sam
