Daniel.R wrote:
The bidirectional wheel must have had an active/dynamic OOB quality to it. This OOB quality must have been closely connected to the RPM of the wheel, and it seems to have grown out of balance as RPM increased.
Consider a scenario where you start the wheel in one direction. Before the wheel reaches its maximum RPM, you stop it and make it go in the opposite direction. Would you feel more resistance in this new direction due to weights being statically placed in an OOB position from the previous rotational direction? This does not seem to be the case according to witnesses and demonstrations. The wheel could apparently be stopped at any time and then be accelerated from the new position in either direction with the same gentle force.
Hi Daniel .. we can't know because there is no report of anyone stopping it before it had reached operating RPM ( M. 40 RPM ) which happened in only 1 to 2 turns - that's an average of 1.5 seconds per rotation - so in just 1 turn to 40 RPM it might take 2 seconds and if 2 turns might be less than 5 seconds - very quickly up to speed indeed - on the other hand we also know that if not given enough starting momentum it came to a halt and stood still in that new position ( always a new position ) - I am sure the witnesses would have then continued in the same direction until they worked out how hard they needed to push to get the internal mechs to engage and for it to accelerate up to operating RPM ..
Daniel.R wrote:IMO, this suggests that he probably used CF and maybe gravity to dynamically and temporarily lift weights into an out-of-balance (OOB) position. The unidirectional wheel however, I see as having weights actively placed on one side of the wheel with the help of the overunity lifting technique that Bessler discovered.
I agree Daniel that he discovered and "overunity" lifting technique to lift and shift the internal weights into imbalance, but imo there are special in-situ conditions ( i.e. imo the perturbation and feed-back excitation by the prime mover ) surrounding the use of the "technique" ..
Daniel.R wrote:As I mentioned in my previous post, I believe we should focus on understanding his lifting technique. If GPE is being "created," then it is possible to make various perpetual motion mechanisms, not just a self-revolving wheel. The possibilities are endless if excessive GPE has been created.
There are two possibilities - either a gain in weights GPE for reset was at a very large discount, or it was entirely "free" ..
Either way, what we do know is that methods of lifting internal weights involving mechanical lifts using ONLY Mechanical Advantage ( MA ) techniques are a 100% dead end - that is because MA is a ratio, and nothing more, that allows force amplification so its easier to do Work .. a trade-off of mass and displacement that either side of a fulcrum equal 1.0 when multiplied together ( m1 x d2 = m2 x d1 ) ..
While searching for his special lifting technique ( non-MA imo ) is a major priority, it is also important imo to clear the mind and eliminate the usual suspects and conditions that he, and we, have relied heavily on in the past, but which have yielded only failures to get a discounted lift cost in terms of energy/work done .. that is the purpose of the topic of this thread - to rationalize the prime mover and its enabler - or from my view point, to rationalize the prime mover mechanism and its action, plus how it enables a discounted reset of internal swinging weights to continue the
chronic wheel overbalance ..
B. said ..
"anyone who wants can go on about the wonderful doings of these weights, alternately gravitating to the center and climbing back up again, for I can't put the matter more clearly" – AP pg 295
"on one side it is heavy and full; on the other empty and light, just as it should be" – AP pg 363
