Hi MrVibrating
you wrote:
There only seems to be one solution here:
• the radial GPE drops, moving the diametric levers apart - that is, one moves 'up', the other, 'down'
Since they're pivoted to opposite sides of the rim, this actually means they're both rotating in the same direction, so inducing counter-torques in the same direction back to the wheel / net system
Rotating 90° we'd still have the under-balance rather than over-balance, and another 90° after that, we'd again be inducing cancelling torques from the levers with a second GPE drop..
That is all correct but a 90° will not work, you must repeat the cycle after 45 degrees.
Remind Besslers words, the force must be applied in the right/correct angle.
Senax wrote: I agree with that. We cannot get energy from Newtonian Gravity (NG).
But we can get energy from Ersatz Gravity (EG)..
If this refers to 'centrifugal potential energy' then all of my findings have consistently indicated that it is simply another way of referencing rotational KE.
CF force can be modeled as mass times radius by angular velocity squared, and work done against CF force can be integrated as the above metric times radial velocity, times time; it is unwaveringly symmetry-bound as it contains no time-variant components.
The only reason Bessler was able to break symmetry is that gravity is a time-constant rate of change of momentum (ie. a uniform acceleration applying to masses), whereas mechanical speeds are somewhat arbitrary, and may also be influenced by transiently-reactionless forces (such as inertial torque / the ice-skater effect); the symmetry thus broken is inertial; a closed-loop gravitational interaction has zero net energy, but potentially non-zero net momentum (so you can gain more momentum from gravity in falling, than must be shed back to it in rising) - this is the same principle we use to gain height on a park swing.
Momentum-from-gravity is demonstrably 'a thing' - and the brief here (in this thread) is gaining it specifically by sinking counter-forces / counter-momenta to gravity (as demonstrated above).
The prospect of ever gaining energy from a closed-loop centrifugal interaction is on precisely the same footing as that of 'energy from gravity', and i'm sorry but i will not be drawn into any discussions to the contrary without presentation of new facts circumventing the inherent time-invariance constraints..
ETA: and FWIW, i've already tried using these same principles to gain momentum from CF force.. finding that it is impossible. It only works with gravity.
When attempting exactly the same interaction with CF force, radius is inevitably changing, and with it, angular inertia, and hence, angular velocity; and with it, CF force. No combination of 'ice-skater effect' nor any other mechanics i have found are able to wring a net momentum rise from a closed-loop trajectory through a centrifugal force field.
And incidentally, applying neologisms to reference commonly-understood terms adds nothing to their comprehension, and is not the mark of 'earnest science'..
Senax
Post by Senax »
Let's agree that one of us is wrong. 😊
The reason we have time is so that everything doesn't happen all at once. As you so aptly proved, if we can believe your testimony, momentum can be accumulated. To what end? Perhaps to do work? That sounds like energy to me. And the message coming from my bones says, wooooooooo Who-oo-ooo-ah, leave it alone.
But, I can't. If energy can be manipulated as you suggest, why can't time be
manipulated. It is purely mechanical, this analog computer I envision. It's a time machine.
Independent of reality. It's going to rip it up. Seven Nations Army Can't Hold It Back.
How you like dem apples.
Your thesis sir appears to me to be disconnecting an action from a reaction. In your words,
decoupling. The only way I can imagine that to happen is if you jump out of reality, work
your magic, then jump back into reality.
How is it that you propose to make this happen?
The coupling and decoupling are a necessary function in the Bessler Wheel.
If you have a regrid, fix bound then you cannot generate a swing.
A mechanical oscillation System Needs space to move !!
So MrVibrating is absolutely right with his Interpretation what is going on in the Wheel.
That what you will not see, that Bessler has used such a jump function in his Wheel. So there is no magic, I for myself are in the reality.
So stay in your dream WaltzCee.
The function for the automatic coupling and decoupling is already there,
I have developed it.
No one is talking to you, George. Where is your Carpenter's boy? Is he still on vacation?
The Carpenter's Boy has done his work, I already showed the Pictures from his work.
I have the choice to present or not present my forthcome on this board, because I built or better let built model by model.
Sometimes it takes time, and you have to wait for the result and presentation, but the solution is there.
And that is for the one and also for the bi-directional Wheel.
WaltzCee wrote:Your thesis sir appears to me to be disconnecting an action from a reaction. In your words,
The thread objective is decoupling per-cycle momentum yields from RPM.
The problem is encapsulated in the first post:
- gravity is a time constant rate of acceleration; you only get so much acceleration per unit time
- mechanical speeds (such as RPM) are variable, and we want ours to increase..
- this means there's less time per-cycle for gravitationally accelerating mass, the faster a system rotates
Likewise, less time for sinking counter-momenta to gravity, and hence collecting the remaining 'positive' momentum.
Follow through the maths of OU and you see that it requires stabilising the unit energy cost of momentum - whereas normally, it gets more expensive the more we buy; per KE=½mV², the cost specifically increases by the square of rising velocity.
Usually, this rising cost manifests in the form of increasing distance between the two masses the accelerating force is being applied between; the faster the accelerated mass gets, the further away it gets from whatever mass it's being pushed against, and so the greater the distance over which a given force must be applied to maintain acceleration.
But we can overcome that constraint by using gravity and inelastic collisions, to yank the 'stator' along with the accelerated mass. Basically, towing our reaction mass along with us. We use gravity to absorb the counter-forces, preventing counter-acceleration and thus counter-momenta, then simply crash the accelerated mass into the non-accelerated one, sharing back the momentum gain.
Sir, you HAVE to do these maths to understand what the hell i'm on about. No word games or sophistry will aid comprehension. The only way to actually get a coherent grasp on mechanical OU, that i have found, anyway, is to just follow the standard equations of motion involved, and plug the numbers, while wearing a bra on your head.
So calculate the input and output energies of a series of reactionless accelerate-and-brake cycles, and provided your chin-straps are fully tightened (i use double-D cups but i've quite a big head) you should see a resulting energy asymmetry..
That's really all there is to it..
WaltzCee wrote:If energy can be manipulated as you suggest, why can't time be manipulated.
It should when he'd be correct.
Yet energy is actually a conversion factor where time is made invariant. It's the same reason why mrVibrating's is mistaken with his misuse of the kinematic formulas.
mrVibrating wrote:you HAVE to do these maths to understand what the hell i'm on about.
Oh well, kinemagic based on a quadratic blind spot is not for everyone.
With his simulator he should be able to easily visualize his "word game and sophistry" in the same linear fashion where weights bounce inelastically and gain in speed as claimed.
Then we can observe the velocity meters to see how it explodes as claimed. When sufficiently understood, we can always ramp it up to a rotational version.
He can't shown such thing. Because he needs a setup that requires "reinterpretation" via his kinemagic process to arbitrarily increase reference frames per cycle (I think that explains his math mistake in the simplest way) in order to prove that kinemagic indeed increases momentum.
I suspect mrV is doing it on purpose as he's very fast in claiming to be able to integrate the centrifugal situation and conclude Senax is wrong.
I think he's indeed able to work out that integral, and is correct in his statement.
The same type of integral can be applied on the gravitational situation which is much simpler.
Thus...
silent
Post by silent »
Ex Silentio wrote: I appreciate your approach to this problem using your math and intricate knowledge of the forces involved.
I absolutely don't understand the math behind the physics and the physics behind the math.
Thanks for that 'expert' opinion. So much appreciated!
Ex Silentio wrote: All this simple talk, yet why is it so hard to solve? LOL! Anyone who claims to be an expert yet can't even construct the "simple" working wheel is no expert.
Why...? Because the math will tell you why it fails every single time!
Perpetual motion is NOT low hanging fruit.
How it may succeed is something yet to be determined (or in Georg's case, yet to be demonstrated)
I do absolutely agree with mrVibrating that one needs to find a principle exception first so the rest will "just become an engineering issue".
His attempt is admirable and the way to go, but the math is a bit kinked.
Glad mrSilent corrected that insight.
silent wrote:Well I see WaltzCee is still at it. It seems like whenever we are cruising along enjoying reading posts and then suddenly things take a turn for the worse, you can always count on it being due to a select few posters.
Sometimes I get notifications of new posts and then when I log in, there is nothing there which tells me there has been yet another post from someone in my blocked list - which I highly recommend to everyone if you can't help but try to offer rebuttals. It'll get you nowhere - just more arguments from the armchair crowd. No wheel - NO expert.
Absolutely bang-on about the 'ignore' list, total god-send. I'm trying to only use it for malicious posters tho - 'dumb' is forgivable, but 'insulting' with it is the real rant-bait (cos i will, can't help meself).
While a given poster might not very likely have any constructive feedback to offer, a chance to recap could benefit someone else.. but i'll only repeat myself so many times before it gets irritating.. (Grrr!)
For Waltzee and anyone else struggling to keep up; the M.O. is simply plying gravity to eat our counter-forces / counter-momenta; the resulting momentum gain is reactionless... and the value of 'reactionless momentum' is that its cost of accumulation needn't track ½mV² - ie. it circumvents the practical constraints that are usually responsible for causing the energy cost of momentum to increase with velocity. So, reactionless momentum is, potentially, cheap momentum.
I say 'potentially' as, in all attempts thus far, nature has always found some other way of causing the energy cost to square up with velocity, regardless. Nonetheless, Bessler assures us that statorless momentum gains are the key to his success ("in a true PMM, everything must, of necessity, go around together"), and all his wheels were statorless, so there must be a permutation that actually works.
And again, the principles behind gaining momentum from gravity really are 'kids stuff' - if you can operate a park swing, you're already an old hand at this.
There's two ways, broadly speaking, of gaining momentum from gravity:
• on a swing, we're performing work against centrifugal force, and the rotational kinetic energy gain is precisely equal to the net 'work done' against CF force
The momentum gain, on the other hand, is precisely equal to the difference in period length between 'rising' and 'falling' phases of the swing, relative to gravity's constant acceleration. Spend more time falling and you gain momentum; more time rising and you shed it.
• however it's also possible to eliminate the CF work component (see previous examples in this thread of changing GPE without changing MoI); in these instances, the rotational KE gain is precisely equal to the net work performed against gravity, while the momentum gain is, again, equal to the 'rising' vs 'falling' gravity / time delta.
I think that's enough of a recap for now, anyone still not following will just have to eat dust..
On a lighter note though, Mr.V I appreciate your approach to this problem using your math and intricate knowledge of the forces involved. I absolutely don't understand the math behind the physics and the physics behind the math. As I'm getting older, I have to pick and choose what I want to invest time in and at this stage of my life, trying to learn the maths involved is literally teaching an old dog new tricks. It ain't gonna happen and even when I was a younger man, it wouldn't have happened then either.
So I thank you for systematic approach to this Bessler puzzle. My attempts go in waves now of where I think I have a Eureka moment and then it fades.
Yesterday's moment was inspired by Bessler's quote: Alternately gravitating to the centre and climbing back up again." AP 291
I started imagining a wheel with pegs like a plinko board where the weights had arms like monkeys and as the wheel rotated and pegs went over the top and underneath any given peg with a weight, it would transfer itself around the wheel freely to do the bidding of the master.
Then I read Bessler's quote: “The causative principle of the movement, its ponderous impetus.� GB 56
So then I envisioned a big heavy wheel within a wheel where levers fall out on the upward (lighter) side and pry on the big weighted inner wheel to push it ahead like the child's hoop and stick toy.
As I approach my first year into this, I see why 300 years have transpired with still no expert on wheel construction to have come forth.
Finally what makes me want to bang my ahead against a wall are quotes like this:
“His Highness, who has a perfect understanding of mathematics, assured me that the machine is so simple that a carpenter’s boy could
understand and make it after having seen the inside of this wheel, and that he would not risk his name in giving these attestations, if he
did not have knowledge of the machine.� - PM 95 Joseph Fischer letter
“The Landgrave being, himself, present during my examination of this machine, I took the liberty to ask him, as he had seen the inside of
it, whether, after being in motion for a certain time, some alteration was made in the component parts; or whether one of these parts
might be suspected of concealing some fraud; on which His Serene Highness assured me to the contrary, and that the machine was
very simple.� - PM 97 Willem ‘sGravesande’s letter
“I have been assured that the secret was communicated to His Serene Highness, the Landgrave of Hesse, under an oath of silence, and
he was allowed to examine the internal structure of the wheel. Afterwards, his Serene Highness was quoted as saying to his ministers,
that he believed the machine to be a true perpetual motion machine, and in addition, it was so simple and easy to construct that he was
amazed that no one had managed to invent a similar machine before Herr Orffyreus.� - PM 137 Jean Bernoulli letter
The world should see this principle, in itself so simple, and yet at the same time so deeply hidden, of everlasting motion.� DT pg 209
SIMPLE SIMPLE SIMPLE SIMPLE Argh! All this simple talk, yet why is it so hard to solve? LOL! Anyone who claims to be an expert yet can't even construct the "simple" working wheel is no expert. You can be an expert in forces and mathematics, but to be an expert in Bessler wheel construction is altogether another matter.
Anyway, thanks for tolerating my ramblings. I always look forward to reading your well-thought-out posts. It's something positive and refreshing and it gives me something new to ponder and think on while I'm at work.
Cheers.
silent
Thank you mate, i assure you you can follow the maths, it really is just the KE equation - multiplying half the inertia by the velocity squared - and the momentum formula, which simply multiplies inertia by velocity; the latter's conserved, the former, only if the interaction's 'elastic', which here, they're not.. so momentum's conserved, but KE isn't. I won't condescend you with more examples; like i say, i always check everything with an online calculator myself anyway (no shame in it!).
Those limited maths aside, the mechanics really are simplicity itself - just like the 'red vs green' examples on the previous page - gravity absorbs counter-forces / counter-momenta! So we can use an internal, transiently-gravitating weight as a 'stator' to torque the wheel against; when it's aligned to the gravitating plane we apply torque, and when it isn't, we don't. Colliding with it in-between torques, we share the momentum gains back with it, bringing it back up to speed with the wheel.
Because the energy cost of momentum squares with velocity, by constantly resetting the relative speed between 'stator' and 'rotor' back to zero we're effectively playing snakes'n'ladders with the V² multiplier in the KE=½mV² equation, and repeatedly rejoining the front of the queue to take advantage of the 'special introductory offer' of ½ J per kg-m/s of momentum. Thus, because the relative speed between 'rotor' and 'stator' is always zero at the start of each cycle / 'power stroke', the energy cost of buying more momentum never gets more expensive..
..at least, that's the idea. In practice, as seen throughout this thread, what happens instead is that there's simply less time available per cycle for 'gravitating', as RPM's build up, and so rather than the required input energy rising by the square of increasing RPM's, we're seeing the actual momentum yield decreasing by the inverse-square of RPM, to the same net effect.
And this is what i'm hoping to overcome using these diametric weight levers...
Having said that, i've no clue how or why they should help in this regard, simply having deduced that it must be so because so much of MT seems to be reiterating their usage.
And now, having finally measured their respective MoI's relative to that of the net system, it seems they could be ideally-suited, insofar as enabling the optimum 1:1 ratio between the two interacting inertias in a reactionless accelerate-and-brake cycle; the quickest route to OU, in the shortest-possible number of successive cycles.
Compared to say a radial lever weight (pivoted at the hub, or indeed anywhere else on the wheel, per MT 19 & 20, etc.), which would necessarily have a much lower MoI than that of the net system; for instance if each lever had only 10% of the MoI relative to that of the net system, then each accelerate-and-brake cycle would be at a 10:1 ratio, and since the number of cycles (threshold speed, basically) to reach OU is equal to the sum of the MoI ratio, it'd take 10 + 1 = 11 cycles to reach unity, and 12 to reach 110%; furthermore if the exploit required sinking half the per-cycle momentum gains to gravity (ie. all of the counter-momentum), then those figures likewise double; so 22 cycles to break-even, and 23 to reach slightly-OU.
So, even though i don't know exactly how to apply them yet, there's good reason to suppose they're key to a working system; cos Bessler daubed 'em everywhere, eight ways from Sunday, and also because they're able to furnish the optimum MoI ratio for the most-efficient OU performance envelope (maximal energy gain, in minimal time / speed / number of cycles).
Again, the 'red vs green' examples on the previous page really do amount to all the mechanical complexity required. All i'm going to be trying next is precisely the same interaction, but replacing the 'red' and 'green' inertias with those of the diametric levers, versus that of the wheel containing them. So, same basic interaction, just with different shapes..!
Clear as mud no doubt.. but i've got a rough idea what i'm on about, anyway, so that's all that really matters for now; hopefully the following experiments will speak for themselves..
I've been lucky enough to finish work early enough to get some work done this evening, so gimme a chance to stuff me face and i'll get settled down with some sims..
OK, so let's start working through the permutations; like i say, there ain't so many of 'em, so best foot forward eh..
Objective: Wrangling a momentum gain, from gravity, using these diametric lever weights.
Recall that each one has an individual MoI about its pivot that is equal to twice that of the pair of 'em about the central wheel axis.
This means if we operate both together, at once, then we're getting a 4:1 MoI ratio. This is obviously sub-optimal - a 1:1 ratio causes the smallest number of cycles to OU - so more 'dead mass' needs adding to the wheel body itself, in order to bump-up its MoI to match that of the pair of diametric lever weights.
For now, this 'dead mass' is just a stand-in, that can eventually be replaced with more functional 'stuff' (such as a GPE, scissorjacks, cats or whatever), once we've found a lever action that seems to work.
If experience is anything to go by, any given approach is likely to succeed only so far before hitting a wall; at which point we'll just have to try another permutation..
Since we already know the MoI's, i'll just re-use the 2 m radius model from two pages back:
The lever weights each have an MoI of 19.8147 kg-m², so when operated in unison we have 39.6294 kg-m² of 'reaction inertia'...
..so we need to make up the MoI of the wheel body to match that value.
We know that the axial MoI of both levers - about the central axis - is 9.6838 kg-m²..
..so we need to add another 39.6294 - 9.6838 = 29.9456 kg-m² of angular inertia to the wheel body..
The sim allows us to cheat here - we could just plug in any MoI we like, regardless of the wheel mass or its radius.. however, it's easy enough to work out how much mass to add to do it 'properly', by simply inverting the MoI base formula MoI=mr²:
• m = MoI / radius²
Hence:
• 29.9456 kg-m² / 2 meters² = 7.4864 kg
..and so, entering this as the mass of the wheel body, using the 'shell' setting (all mass concentrated at the rim, like a ring), gives the desired 29.9456 kg-m² of extra MoI, which, in combination with the axial MoI of the weight levers of 9.6838 kg-m², provides a total axial MoI of 39.6294 kg-m², equal to that of the paired weight levers about their rim pivots!
So now we have a 1:1 inertia ratio, we're ready for some action!
OK so with gravity enabled, let's try moving the levers apart:
Absolutely FA happening there eh?
Gravity might as well be turned off!
The same thing's obviously gonna happen moving 'em back together - it'll just reset the wheel angle... but either way, this motion evidently can't cause a net momentum change.
N3 remains intact.
So, that's one permutation ticked off..
