So here's a pair of leaf springs attached to a basic vMoI:
..as the black weights alternate inner / outer positions, +/- inertial torques are produced, accelerating and decelerating the wheel, and thus with it, the spring axes.. it's the friggin' ice-skater effect, with all floppy arms, like, bashically.
I've tried every type of linkage from pulleys to cranks, but can only get 'em rolling consistently at best, with no kinds of gains.. obviously, it's not at all clear how you might go about rectifying a directional momentum bias here, there isn't even a collision, and no obvious way to apply one usefully anyway..
But then consider the options:
• all the clues - all of the big ones anyway - consistently point back to this kind of 'cross peice' arrangement, where you have a pair of equal opposing angular accelerations, coupled to a linear / radial one
• the de-facto objective is constant per-cycle momentum yields / costs, remember - this is just the literal embodiment of mech. OU
• so it's nothing to do with a putative GPE asymmetry; ie. the radial load cannot be another GPE, since Bessler would not be dropping two GPE's for the purposes of raising a third, since he knew too well the futility of such bunk
• hence my hitherto conclusion that it had to be for the purposes of an MoI variation, and harnessing the corresponding reactionless angular accelerations / decelerations of the wheel body
But just look at how that pans out above - where to go with it? How's
that get us any nearer to our very specific objective WRT p-c momentum efficiency?
Which is why i'm now reaching for some
other function or ability i've missed there. One outstanding question - Bessler seems to intimate that the connection between the angular / linear motions should involve power conversion / leverage, per the scissorjacks, but how and why?
And so i got to thinking; what happens when we load one of these springs up, then move it
through the axle, to then
unload on the opposite side of the wheel?
To my addled thinking, it's similar to the effects of flipping the face of a spinning disc - translating clockwise into anticlockwise spin, for example... here, moving the loaded springs onto the opposite sides of the wheel will likewise translate what would've been a clockwise torque into a CCW one, or vice-versa, geddit? So the spring loading and unloading cycle would be applying consistent torques to the wheel in one direction.. ie. loading the spring might apply an anticlockwise torque to the wheel, but then unloading it on the opposite side of the axle would
also apply
another anticlockwise torque, and so each full spring cycle accelerates the whole system a lil' bit at a time.. constant input energy p-c, for squaring net rotKE, no?
Or am i talking complete shite again?
If the premise still seems semi-coherent tomorrow, i may make a start on trying to sim it. Sounds tricky to do tho eh.. Dunno, crazy talk prolly..
