here is yuor Perpetual motion
Re: here is yuor Perpetual motion
I think ultimately, only a replication will tell us how much the stick will rise, if at all.
Replication by several people would help build a result data set for or against.
Until then I leave this concept as valid.
perPedes
Post by perPedes »
perPedes wrote: Tue Oct 25, 2022 8:26 pm here the calculation in english https://www.hwcv.org/kopie-22-2-22-22-22-22-22-22
The question; would a stick that is water repellent raise up more than one that is not treated?
Thanks for the translation
perPedes
Post by perPedes »
if the stick is water repellent, the effect would be smaller
Re: here is your Perpetual motion
perPedes wrote: Wed Oct 26, 2022 12:30 pm if the stick is water repellent, the effect would be smaller
Interesting opinion which means the stick is floating in the water sticking to, pardon me, the stick.
Testing will show of cause. I go with the idea the water height within the glass hoop [5mm] causing the water level going up. Then the stick [1mm] floating to that new level.
I can also appreciate if the stick is repellent then the stick will not be floating in the same height of water. Therefore what is it floating in - air. I think not.
But if the stick is repelling water down around the stick then is it not being push up with an equal and opposite force?
Just a notion
If the hoop was a tube [5mm] gap with the stick [1mm] within.
Then sucking the air out would raise the water level as the water enters from a bowl of water.
One would expect the water pressure in the tube to drop and the stick to float less as the water level goes up.
Thanks you for your reply.
