A good lead ?
Re: A good lead ?
@Shadow, of course a spring is possible, but that's not really the problem, the most I can see is that the balance wheel makes 3.x oscillations while the inertia disk makes only one revolution. Enlarging or shortening the rod that holds the weight of the balance allows you to adjust the number of oscillations, in this experiment I didn't take this detail into account, the devil is in the detail... I reassemble the whole thing to get a clearer picture.
Re: A good lead ?
Is perpetual motion possible?
In principle, no. The conservation of energy tells us that it isn't. Others say it's impossible because no one has yet shown that it could be.
Gravity isn't a source of energy, and energy can't be created.
But Bessler, without having shown how, has demonstrated that it could be otherwise.
Bessler, not being a magician, used gravity, or rather potential energy rather than kinetic energy, as weights above a certain speed no longer fall.
He succeeded in resetting the starting point of potential energy. In other words, the point at which the fall begins.
When he says that one kilo can lift 4 kilos, the Romans already knew this, he's not teaching us anything and he knows it, he's simply saying that the heavy weight is certainly the highest and that it all works in pairs.
All this to say that I have no doubt about the why (it works), but I haven't yet found the how. The motor is probably a pendulum, and this pendulum is motorized for half its cycle, the second cycle is momentum, the pendulum no longer weighs. How?
Re: A good lead ?
Je pense qu'il y a un système de verrouillage gravitaire intermittent pour permettre le déséquilibre du moteur primaire!
Ensuite le potentiel de puissance est obtenu par un déplacement amplifié sur un coté!
Cela reste mon hypothèse du jour!
I think there is an intermittent gravity lock system to allow the imbalance of the primary motor!
Then the power potential is obtained by an amplified displacement on one side!
This remains my hypothesis of the day!
