I think this is an important piece of text , there is so much more to think about when you start thinking about what kind of mechanics could Bessler possibly be talking about.The design has, in fact, progressed to the point where there is nothing supercritical about the exact disposition of the weights - an ounce more or less, here or there, makes not a scrap of difference to the Wheel, which will hold its course serenely without 'turning a hair'.
For instance , there was a time when the exact disposition of weights were supercritical to function , but the design developed to a point where it did not matter anymore.
Disposition of weights , if we are talking about weights going in and out , why would the exact disposition have been supercritical at one time , and then not anymore .
If the weights are guided by limited movement for example between stops on arms , or going in and out limited to arms they are fixed on , or limited by the structure , how would an "ounce more or less here or there" even be possible ?
If the weights were free to "roll" inside some guided slots or shape , the also I cannot see how "ounce more or less here or there" would be possible .
If this was a "paternoster" type design I also cannot see how "ounce more or less here or there" would be possible.
If this was a design where there was suppose to be more weight on one side than the other , then how on earth would there be a scenario of an "ounce more or less here or there" since weight would be hard guided by something.
It would seem to indicate weight could move more or less in some unrestricted manner perhaps in X and Y, for example a swinging weight might produce an "ounce more or less here or there" scenario .
What else could also do this ?
Perhaps timing?
