My First Attempt (and failure) at Bessler Wheel...
Sean
Post by Sean »
http://youtube.com/watch?v=Cfy5W5ZmVvs
My first attempt :-).
~Sean
graham
re: My First Attempt (and failure) at Bessler Wheel...
Post by graham »
Don't feel bad,we've all "been there done that". Welcome to the fold Sean.
Nice animation though. How did you do it ?
Sean
Post by Sean »
I used a program called "Interactive Physics". I bought some physics books for college, and it was on one of the disks.
http://www.design-simulation.com/IP/index.php
I think I saw some people on the forum mention Working Model 2d. This is by the same company (and looks almost exactly like the same software, just a different name).
~Sean
Tinhead
Post by Tinhead »
It is the same thing, you can even exchange files between them. All you have to do is to change the file extension. So you can load all the published examples here on the board :)
Change *.wm2d to *.ip ( is it ip?, you get the idea)
Works fine.
Cheers,
Rainer
pstroud
Post by pstroud »
Hi Sean!
Welcome to the forum and search for perpetual motion!
The animation was nicely done. Bessler's writings state that nothing can be accomplished by the rolling balls concepts. However, I'm open minded. When I saw your animation, my first thought was to install some little light spring latch stops along the track the balls roll on. The ball rocking back and forth seems to keep the wheel from moving a step forward.
However, if you gave it one hard spin, that would overcome the need for latches and the faster movement would keep the balls from rocking back. If it were out of balance, it would just keep moving.
Check out Bessler's MT drawings. There are some very similar that indicate the concept has been tested before.
Just a thought.
Good Luck!
p
