"The Things We Eat...
nneba
Post by nneba »
...run through every limb and sinue of our bodies"
IMHO---When the wheel is in motion, EVERY individual part is in a motion of its own. The weights do not sit in any one position for any amount of time.
Agree?
Timothy
re: "The Things We Eat...
Post by Timothy »
...EVERY individual part is in a motion of its own.
If the principle of "connectedness" is valid, no weight has a motion of its own, but is influenced by another.
Love it quick. You ain't gonna have it long.
nneba
Post by nneba »
Timothy,
Thanks for the reply, glad you agree. The entire system moves in sync. There is no one action then reaction, it is entirely dynamic, and inter dependent.
Maybe the statement was more to do with the blood pumping around every sinew. But, it has to be pumped by an efficient pump that requires energy from somewhere. Where does that extra energy come from?
nneba
Post by nneba »
Tarsier79,
The power comes from the hub, not the rim.
Opposite of overbalanced, I am certain of it.
BTW- If you own shares in power companies, better get rid of em' by next year.
daanopperman
Post by daanopperman »
nneba ,
any weight being lifted by the wheel on the side going up have a downward push on the wheel , if you use a lever to gain leverage ,you multiply the force , but if you lift the weight on the side going down , you will put all effort you use to lift the weight straight into the shaft/wheel , so you don't lose any energy lifting the weight .
agree
nneba
Post by nneba »
Daanopperman,
I suppose I must agree with you, but remember that greed is an evil root (route)
Only the slightest amount of rotation/force will be required to reset the prime mover.
Overbalancing = greed, I was going to get into the details of my latest wheel (took about 20 hours) but instead I will just build a runner, and show you then.
smiles
nicbordeaux
Post by nicbordeaux »
Tension runs thought every sinew and bone. So does electricity. tension is preload, a form of PE.
nneba
Post by nneba »
Nic,
Yes, correct tension is paramount.
The old dog only goes as far the chain will let him.
Andyb
Post by Andyb »
Nmeba,this is the same as nothing ever reachs a point of rest and every thing retains the power of free motion ,from what i have learnt if you cause the weight to reach a point of rest then you can not generate enough energy to get over the negative torque weight,i personally believe the weights act in pairs as Bessler said ,the key i beleive is figuring out what lifting a lb with a 1'4 meant.good luck warrior. Andy
