Updated Algoodo version
phj
Post by phj »
Good news for those of you who use, or are considering using, the 2D simulation program Algoodo from Algoryx. After many years of inactivity, the program is now being updated again and is available in a 64-bit version for both PC and Mac!
https://www.algodoo.com/download/
phj
PHJ
Re: Updated Algoodo version
Attention!
La nouvelle version d'Agodoo n'est pas compatible avec Window 10.
Je l'ai installé et il plante au démarrage, j'ai du retrograder vers la version 2.1.
Be careful!
The new version of Agodoo is not compatible with Window 10.
I installed it and it crashes at startup, I had to retrograde to version 2.1.
phj
Post by phj »
Hi Shadow,
Tried installing the new version of Algodoo on my old Windows 10 PC, and it runs perfectly. Maybe you have a graphics card issue? You could try checking here: https://www.algodoo.com/update-drivers/
PHJ
Bonjour PHJ,
Je vais essayer!
Qu'y a t'il de nouveau avec cette version?
Hello PHJ,
I’ll try it!
What’s new with this version?
phj
Post by phj »
Hi Shadow,
Make sure to uninstall Algodoo completely before installing the new version.
Updates:
NEW: onLaserHit and onHitByLaser now has a hsv argument
NEW: Restore markup tags that are now working again (small, sub and sup)
FIX: Widgets flashing on hover on some Intel graphics cards (#67)
FIX: Time spent is really fast on some Ryzen CPUs (#37)
FIX: Missing icon for spongify (#70)
FIX: Widgets move around when Algodoo is maximized and then restarted (#26)
FIX: Color grid sometimes flickers when changing saturation (#69)
FIX: Disable the context menu on web widgets (#51)
FIX: Restore old font aliasing on Windows for small fonts and in WebComps (#50)
FIX: Remove hyphen when box text breaks into a new line (#66)
FIX: The fonts Calibri, Bahnschrift, Yu Gothic, Palatino Linotype and Franklin Gothic were placed wrong in box text (#49)
FIX: The font Verdana with a small text size was using the wrong letter spacing (#71)
FIX: Restore the old behaviour of the big-tag in box texts (#24)
FIX: Font preview widget cannot be opened when the widget is closed with the X button (#64)
FIX: Font preview now shows all font styles for every font family (#68)
FIX: Font preview can be too big to render with too many fonts (causes graphics error) (#65)
-20 fonts are now displayed at most by default.
-If the filter is a single letter, only fonts starting with that letter are displayed.
PHJ
