Posted by Pete (213.122.234.230) on March 26, 2003 at 12:39:22:
In Reply to: Re: Obsessed posted by Anton on March 26, 2003 at 10:44:06:
Anton,
It does not mater about increasing the potential of the wheel until you have the starting point.
Pete.
: SORRY about my last post regarding " / " I stuffed up big time!.Anyway I was thinking about If It would be possible to increase the power of a P.M. wheel if one were to place six small P.M. wheels around a large disk or circular platform.The way I see It is that the P.M.'s on edge of the spinning circular platform would have their weights increased artificialy by three to five G's thereby giving each wheel up to five times more power than before. This means that 5% of each wheel would be used to give power (watts,volts) to run the large spinning platform they are sitting on!and the rest would be for home consumption!Simply It means this,each P.M. wheel's weights would weigh up to five times more.Maybe your thinking It won't work because the weights are heavy to lift and heavy to drop and won't make any difference.My answer to that is a thirty foot high P.M. wheel does the same and gives more power!!.....Anton
