Posted by murilo (200.168.8.167) on April 30, 2003 at 11:13:08:
In Reply to: Re: Matthew 24:35 posted by Voice in the Wilderness on April 29, 2003 at 17:58:24:
I TRY TO UNDERSTAND TO YOU, AND PLS YOU TRY TO UNDERSTAND ME. I WANT TO MEAN THAT IF THE SPRINGS BLADE DON'T MOVE, OR OSCILATE, UP AND DOWN, AT ADEQUATED RYTHM, THIS WHEEL MUST NOT MOVE. IF YOU NEUTRALIZE THE BLADES OSCILATION YOU'LL GET ZERO SINETIC BEHAVIOR AND NO WAY FOR TO REDUCE AND/OR PULSATE PERIMETRAL EQUILIBRIUM.
PLS BE ADVISED, I'M NOT A ''BELIEVER'' TO YOU AND TO YOUR DRAW, I JUST DID LIKE IT AND I SEE POSSIBLE WORKING. IF YOU ARE SO INSPIRED AS YOU SAY, I WOULD RECOMEND TO YOU A SHORTER ARROGANCE, AND YOU'LL APEAR MORE ELEGANT AND BEAUTIFUL IN THIS MOMENT OF POSSIBLE GLORY. REGS. MURILO APR/30TH
: The springs themselves are normal springs and need no resonance or vibration to work....I would say that this is a misdirection.
: Peace,
: A Voice in the wilderness
: : I SAW IT IN ANOTHER GROUP. IF THE SPRINGS TREMBLE IN THE RIGHT PLACE, AT THE RIGHT FREQUENCE, AT PROPER ROTATION, THIS STUFF WILL TURN AT LEAST FOR LONG TIME, BECAUSE A PULSATIN RELIEF WILL OCCUR IN THE PERIMETRAL PARTS, NEAR 9 TO 11, AS CLOCK. THE POWER POSSIBILITY INVOLVED WILL BE POOR. MURILO SP 29/APR
: : : And I say Mithras and many other god men of whom were the templates for the Jesus story existed thousands of years before hand.
