Posted by A Voice in the Wilderness (67.31.157.182) on May 04, 2003 at 23:04:50:
In Reply to: Re: Video of simulated storage of weight energy in a spring ! posted by Stefan Hartmann on May 04, 2003 at 19:40:33:
The one shown to me as posted to the forum below was, I believe, divinely revealed to me. Our FATHER in Heaven, I believe, is revealing now that there are simple things of his that confound and fool the supposed wise. It is, in part, HIS way of telling the haughty and arrogant ones that HE can see that there is "No honor among thieves". The "thieves" here being those that lead GOD'S children astray by their teaching traditions of men as "laws" and telling HIS children that there is no GOD. The lack of "honor" stems from such ones who have told many that follow them that their "laws" cannot be broken.....and when they are broken......where are these men? Their "honor" has fled! Not many of these outspoken "lettered men" turned "heretics" will then honorably come to the fore to register anything resembling a HUMBLE apology for their egregious error. The same has been true since the beginning. It really was not that long ago that it took an act of the then president Theodore Roosevelt to quiet the cacophony of cackles from the "lettered men" from their science pulpits regarding the Wright Brothers and their alarming and rapidly spreading "heavier than air" human flight hoax!
Regarding the device, I submit that perhaps a number of other polygonal shapes may substitute for the one I posted, I am looking closely at a 7 segmented wheel as well. Burt Rutan, the famouse aeronautical engineer once designed his expensive home around a 6 segmented water wheel of his design that converts gravity to continual rotary motion. His whole house is hexagonal and hardly a right angle can be found in it other than the upright walls! The "working moment" of his wheel relies on the fact that water poured into a level cistern can be made to transfer energies almost instantaneously from the resulting overflow at the location of choice, in his case, from a dumping point into an upper cistern near the hub of the wheel, an overflow resulted in dumping water at the periphery. It caused quite a stir in physics circles in 1989. What we have occuring in the spring design I have shown below and elsewhere, is the continual release of stored energy converted from gravity stored in springs in such a way as to be beneficial to a given direction of spin. It really in no way relies on esoteric and mysterious forces for it merely taps into the fabric of gravity to sustain it's motion and I suppose many of the most vocal opponents of "perpetual motion" or "overbalancing wheels" will take it in stride and be some of the first on the "bandwagon" as though their former selves never existed! GOD bless them every one! I truly hope that many of our FATHER'S lost ones who now follow men rather than GOD will sit up and take notice that those they have chosen to follow are fallible indeed and so is their "gospel". They may then begin to question what else they were taught.....like "evilution" and the like.
GOD bless all of you dear readers in Christ. FATHER please send your Son soon!
: The recent development of:
: http://www.kuenstler-energie.de/img/M13-Animation.avi
: is also simular in concept:
: There are also 2 oscillator system:
: 1. The wheel
: 2. The pendulum inside.
: Now they use the trick, that lifting the weights at the top
: will also force the pendulum to store this energy in height
: of the pendulum swing.
: With the next swing of the pendulum, it will have force
: to lift the next weight at the top.
: Also here applies:
: the 2 oscillating systems must be synchronized for the right frequency, so the whole system can turn on.
: So the weight of the pendulum and thus the swing frequency must be fitted to the rotation speed of the wheel !
: One problem I see with his system:
: the lower left arm of the pendulum sticks the weights
: out at about 6 to 7 pm (comparing with a clock).
: This must not be.
: The pendulum weight should move free at the buttom !
: The upper arm of the pendulum will transfer enough energy
: to the
wheel.
: : The weight and the spring is just an oscillator system !
: : As the weight osillates over the center, the wheel
: : turns and converts gravity energy into rotation energy.
: : Now the trick is to SNCHRONIZE these 2 oscilating system
: : 1. Spring with mass
: : 2. rotating wheel with all its masses inside
: : that way, that the spring with weight oscillation will
: : be in right synchronisation to the wheel rotation speed.You have to find the right spring constant pull factor and also you
: : have to find the right weight for the wheel to rotate in sync with the oscillation of the spring/weight.
: : If these right parameters will be found, the wheel will
: : increase in speed,due to every rotation gains energy from gravity, until the friction forces will limit it.
: : Please let me know your comments.
: : Thanks !
: : Regards, Harti.
: : harti||harti.com
