Re: message to OVYYUS
Posted by murilo (200.168.8.167) on May 22, 2003 at 09:02:52:
In Reply to: Re: message to OVYYUS posted by ovyyus on May 21, 2003 at 19:18:58:
Ovyyus, hello. Thanks for your consideration. Personaly I think that it's easier if one state himself as a free thinker, and just try to reach to something throughout own means. It's much harder to fall to somelse hidden clues. The ''adventure'' is almost the same. My avalanchedrive project is now stoped right in the point you can see in the photo. Up to the point a man can be, I'm sure it will work. In this moment I'm trying to find a local partner down here in São Paulo. For the while, I try to find people that reach to the understanding and to this conclusion point: ''just a model will say''. You see, I don't look for believers. THIS IS AN OPEN IDEA, AND THERE ARE MUCH TO BE DISCOVERED ABOUT. Best regs. Murilo SP may/22 .
: Hi Murilo,
: Thanks for your kind comments.
: If Bessler's secret was as simple and as obvious as Karl said it was, then there is perhaps every reason to expect "the motion" to be hidden amongst his unpublished drawings. IMO, the solution will be found in some combination of the mechanisms depicted in MT, exactly as he claimed.
: MT begins with simple and obvious attempts at solving the overbalanced wheel problem - and ends with a bunch of kids toys! There's lots to look at. It seems to be arranged like a kind of lesson or guide towards his final solution. But of course the critical page/s are missing, aren't they - what a tease.
: Have you built a model of your design yet and what was your conclusion?
: Regards, totally ovyyus
: : Hi, Bill. The good labor you are doing forces me to congratulate and to thank to you. It helps a lot in the appreciation to that german genius. Personaly I think that if his best solution would use a very special CLUE, it would be very clear in some draw, at least in part. So, I believe that the Bessler wheel should use, as he said, combined solutions that are all there. I confess that some draws I couldn't understand... do you? Is this case, you must be so well trainned, that I would ask you for to take a look to my own conceptions, of sure when you get time. They are hard to be understood, and flexible trainnig and patience must be used, just before the comming of a flash!! A kind of challenge! Can you give me a hand, please? (you'll find them at www.alzimach.net , in Gravity Motors,''FRCM,Fractioning...''). Thanks again. All best! Murilo SP may/21
