Posted by murilo (200.168.8.167) on May 28, 2003 at 11:39:38:
In Reply to: Magnetic Repulsion posted by Paul on May 28, 2003 at 09:15:11:
Paul, (if nobody else have better informs about) at least for some magnets catalogs I have seen, these 2 forces are equivalent one to the other. Also I could see they are, roughly, with the use of a commercial common balance, with the use of 2 equal magnets. Regs. Murilo
: I have a question that I need some help in answering. I would like to know if a Magnet can Repel the same amount of weight as it is rated to be able to "lift"?
: What I mean is, if a Magnet is rated to be able to lift 195 lbs. does it also repel objects up to 195 lbs. also?
: Thanks.
: Paul
