Re: Clarification request for John Collins
Posted by Øystein Rustad (217.70.229.39) on October 29, 2002 at 09:37:22:
In Reply to: Re: Clarification request for John Collins posted by grim on October 28, 2002 at 14:59:01:
That is a modifiable truth...
There are only 2 right angle points to an axsis, when we talk about weight (gravity) !
To apply (ALL) its weight at right angle to the axis, is only possible when the weight or its attachementpoint is placed horisontally in line with the axle, since the gravity is applying its force vertically !
Even a weight placed at 3 o`clock or at 9 o`clock close to the axle, will actually apply its weight at right angle to the axis..
The only "perfect" way to avoid right angle to the axis at all is to climb/be dragged up an incline past the right angle piont..
But that is mathematically of no use.
And can be rouled out, since Bessler used no external attachementpoints except from the axle.
What he most likely meant, is FULL arm at right angle to the axis, as John C. stated.. ?
Øystein
: Since an axis is basically a circle, there are an infinite number of right angle points in relation to it.
