Posted by John Collins (194.164.38.13) on December 11, 2002 at 23:53:40:
In Reply to: Re: Weight dimensions posted by MrTim on December 11, 2002 at 19:40:25:
Just a quick point. Don't forget that the 40 lbs per weight was an early estimation of mine and the true weight could be much less.
John C:
Hello everyone!
: A 4 pound weight (assuming it's made of lead*) only measures 2.5" diameter x 2" thick (3.92 lbs. actually) If a hole is cast or drilled through the center, it would allow weights to be 'stacked' on a rod. Also, being in a modular form allows for easier handling. (I've stockpiled over a 100 lbs of lead. Even in 2 lb chunks it's a bear to move small amounts. Imagine trying to install a single 40 lb weight in a wheel and you'll see why a modular installation makes better sense...)
: MrTim
: * Lead makes sense because it's heavier, and easier to work with, than iron. Lead is HAZARDOUS, so take proper precautions if you are going to use it. And by hazardous I don't mean dropping it on your foot....
