Posted by Bob P (62.252.0.5) on December 19, 2002 at 05:57:40:
In Reply to: Re: Open Question To Group On Heat posted by Øystein Rustad on December 19, 2002 at 01:54:42:
: You are right that all energy will at some stage become heat.
: I see your point, the question is still : Is it gravity that heat all planets cores, because of the dynamic Etherflow that gravity very well might be ? if so, there is a possebilety that the energy drawn from a Besslerwheel do not end up as energy in the core of the planet.
Thank you for your interesting thought.
Perhaps we need to look at gravity in the same way we look at other energies, such as light (electromagnetic).
An example:
If we cover the ground with a solar panel, the light/heat (both electromagnetic energies of different frequencies) will not reach the earth.
However, the electricity generated by the panel can still be used to do useful work, if we want it to (e.g. drive an electric motor). The First Law still holds true.
Perhaps we need to look at a Bessler-type wheel as having the potential to also extract energy instead of just letting the gravitational energy "fall" on the earth. (I realise that scientists will laugh at this idea).
