Re: Open Question To Group On Heat
Posted by Scott Ellis (216.87.95.64) on December 19, 2002 at 21:53:26:
In Reply to: Re: Open Question To Group On Heat posted by Øystein Rustad on December 19, 2002 at 10:58:42:
Hi Øystein,
Of course we're interested! As you know, I (for one) have an affinity for ether and push gravity theories... Please go on! ;)
I think that it is quite likely that an energetic ether causes gravity as we know it, as well as the internal heating of massive bodies in space. A great book on the subject is Matthew Edwards Pushing Gravity, which I highly recommend.
http://users.aber.ac.uk/cat/Critiques/Edwards.htm
http://www.metaresearch.org/publications/books/PushingG.asp
And here is great set of gravity links I just found... enjoy!
http://pw1.netcom.com/~sbyers11/GravLinks.htm
And here's some about ether theories
http://www.magna.com.au/~prfbrown/aether.html
-Scott
: By the way :
: A conservation problem may though occour IF we find out that the (possible) Ether flow will not be reduced by a gravitywheel harnessing the Ether flow....
: Did you know that gravity can be proven by Einsteins equations to be Etherflow in towards masses ?
: And the derived equation
: (from Einsteins equations for time delay)
: for etherflow will be :
: Ether Velocity in towards a mass = (2GM/r)^1/2
: And it will be the same number and formula as for to calculate Escape velocity for a planet !!
: (If it interests you ?, I can explain why ! )
: : Thank you for your interesting thought.
: : Perhaps we need to look at gravity in the same way we look at other energies, such as light (electromagnetic).
: : An example:
: : If we cover the ground with a solar panel, the light/heat (both electromagnetic energies of different frequencies) will not reach the earth.
: : However, the electricity generated by the panel can still be used to do useful work, if we want it to (e.g. drive an electric motor). The First Law still holds true.
: : Perhaps we need to look at a Bessler-type wheel as having the potential to also extract energy instead of just letting the gravitational energy "fall" on the earth. (I realise that scientists will laugh at this idea).
