Posted by grim (206.162.192.40) on June 11, 2003 at 23:38:14:
In Reply to: Rotating in Reverse posted by ovyyus on June 11, 2003 at 22:41:57:
: Bessler stated that, during demonstrations, he would allow his wheel to be pushed or turned in any manner desired, stipulating only that the wheel must not be forced to rotate faster than the maximum speed for which it was designed.
: That being so, Bessler would have had no objection to someone turning his uni-direction wheel in reverse for as long as they liked.
: This raises a couple of questions: 1) Did the uni-direction wheel exhibit an overbalancing force when rotated in reverse? 2) Did the uni-direction wheel exhibit rim impact noise when rotated in reverse?
: IMO, if the later bi-direction wheels were composed of two joined back-to-back uni-direction wheels then, IMO, the one-direction design must have been silent when operated in reverse, otherwise the bi-direction wheels would have exhibited rim impact noise on both sides of the wheel.
: Furthermore, if the overbalancing force acting on the wheel was accompanied by unavoidable rim impact noise (Bessler said he couldn't silence the noise) then, IMO, the uni-direction wheel exhibited no torque (was balanced) when turned backwards. No noise = no torque.
: Question for those presently building wheel attempts: Can your design be turned in reverse without problems?
: Regards, ovyyus
Hi Ovyyus
Will let you know as soon as its completed. The enlarged machined version is exhibiting the same characteristics as the "slop model", so am encouraged here. Working on locating, or in worst case, fabricating the "principle piece" that JB spoke of, rest of it done.
If you check Alden Park's "Little Book Interpretation" the unidirectionals displayed at Gera and Draschwitz made a "ticking" noise from their "Offyrean roller bearings" that he felt was necessary to disguise with noisemakers. You may find that a lot of the
"weights fell on warped boards" may just be a lot of noise.
