Posted by grim (206.162.192.40) on June 12, 2003 at 06:00:41:
In Reply to: I just had to pipe in-a possible minimalist design? posted by Vector Viper on June 12, 2003 at 03:58:03:
: With all these wheels getting done and spring discussions,
: etc...
: I have a great idea for a 'overbalanced' wheel using only
: ONE weight. If it works, it has to be the simplest design
: ever (if a VERY shaky one). Parts of it has been tested in
: Working model, and it looks promising...in this design, the
: 'wheel' is only used as an energy sink/source, as a flywheel
: giving and taking energy from the separate arm/weight/spring/gear
: assembly attached to it with a belt or chain.
: The weight is never moved in or out, so centrifical force
: is NOT a problem at all.
: Wish me luck on this one, it's way out there designwise...
: Viper
Hi Viper
Good idea, try it! Some engines are single cylinder, not two; worth investigating!
