Posted by murilo (200.168.8.167) on June 20, 2003 at 06:49:58:
In Reply to: A possible non-Bessler alternative? posted by Vector Viper on June 20, 2003 at 02:10:37:
Vector, hi. My english skills made me lose part of your meaning, but BE SURE that I have sketches that use auxiliary other chains in FRCM avalanchedrive. They will be good for 2 main versions: a OU assisted by motor at upside, and a direct transmission connection from down to upside. Generally I don't use to talk about variations, in order to don't complicate understanding of people, what is allready a mess. I use to talk more about the basic and naturally pushed open chain. The versions I mean now, since you asked, may send 1:10 (or near) surplus. In my texts, if you read, I'm talking of THOUSANDS of different solutions, in the future, for my conceptions. THEY ARE SO LOGIC AND CLEAR! THANKS for to make busy your brain about my stuffs. All are wellcome and specially you, one of my projects first fans, here in Bessler's site. Regs. Murilo sp/jun/20
: This is a new idea of mine,
: which Working Model indicates is a well over OU contender;
: I test modeled the important part tonight, you can mess with
: various things quite a bit and have it still work well,
: it's not too critical (could be OU by 200% or more)
: It uses ideas from the FRCM device, with weights as
: 'free'individuals, then combined as 1 larger mass which
: barely moves, even though the weights DO,
: lifting the 1, or the few.-I really like this one!!
: "All for 1, 1 for all"-The 3 musketeers
: ...BTW, Murilo, have you considered using
: an additional chain to connect
: the top and bottom wheels of your FRCM idea?
: You could leave some slack at the top, or anywhere-it may
: help if it does not work...
: Also, It uses a strange variation on leveraging 1 weight against
: another (5 weights balancing 1 5x farther away from
: the fulcrum) lets just say there is more than 1 way to balance
: weights off each other... :*) I know Bessler said it's
: pointless to try it, but he just used A wheel...
: Viper 'Peace to all, and good luck to all your designs'
: PS-I'm really exited to see other designs working while
: I make my own!
: PPS-This could be fun, folks!
