Posted by Nick Hall (195.74.122.242) on July 09, 2003 at 06:22:28:
In Reply to: Re: Imminent discoverers posted by grim on July 05, 2003 at 04:59:47:
Grim wrote:
"Just to let you know, before offyre.com came up with MT, I built what can be seen now as MT63. No weights on bottom, topheavy sideheavy wheel, all big weights lifted by a 12:1 lever system with springs to aid the timing. The timing, spring constants, etc. was extremely critical, but when the timing was right it was self-starting and ran, thumping with one pair of mechs only like an idling Harley. Was replicated by e-mailed
drawing to another, who got the same results. The only trouble was the reactions were so violent that it slowly beat itself to death, "
Grim,
Let me be sure I understand you - you are saying that you built something like MT63 which was solely gravity powered, kept running, and _SLOWLY_ "beat itself to death"???
Is that correct? In other words, you made an actual physical model, not a CAD or similar...?
In which case:
-- how long did it run?
-- did it make a lot of noise?
-- how much of a start did you need to give it?
-- did you try it powering something else (i.e. take energy from the system)?
Thanks!
Nick
