Posted by ovyyus (150.101.146.215) on July 11, 2003 at 19:32:39:
In Reply to: Re: Grim - Thanks posted by grim on July 11, 2003 at 17:24:11:
Hi grim,
Re: your design drawing...
The lead weights attached to the small disks are 1.5 lbs each.
The lead weights attached to the arms are 6 oz each.
The angle between pivot and 1.5 lb weight and the pivot and 6 oz weight is 90 deg.
The 6 oz weight is 6 inches from pivot (centre of small disk).
Questions:
What is distance of 1.5 lb weight from pivot (centre of small disk)?
What is overall diameter of main wheel structure?
Thanks grim.
